Focus lamp. Has anybody tried this?
Started by john70490 ·
  • 25Posts
  • 25Replies
  1. I just picked up the La Luz light kit with the 2 batteries, charger, ys clamp, red filter. Nice wide beam, extremely bright, and compares favorably with my Sola 1200. For $200, this is an excellent deal. My only complaint is that the beam has a hard edge instead of the soft edge that the Sola has.
    Edited by Jak Crow
  2. I picked one up recently as well and agree that it is pretty tough to turn on underwater!
    Tried it on a shallow dive last weekend.
  3. I have been using a LaLuz and its excellent. You have to just touch the button to change setting not press it hard. Love using it.
  4. I also don't agree with the what he said of the switch, he obviously hasn't used it underwater as the pressure makes it lighter to push- tested it in a HK apartment!!!!
    The incrementation of power seems wrong too in the review, I think the manufacturers claims are fair and square.
    It's a solid little torch, with the latest tech rechargeable battery.
    If I was going to fault it, I would say the YS style adapter is the weak point, if they made a sprung mount clip for it(like for smgs) it would be a better, but hey plastic things last if you look after them(the design of the plastic mount isn't the best as it tightens past parallel). You could probably bodge up a Inon brand one to work on this, could use multiples for video.
    $200 hard to beat.
    $200 hard to beat.
    Ditto on the button. I thought this was an issue at first when I tried it in my apartment. However, underwater, I have no issues operating it.
