Sigma 15FE + Kenko 1.4 on a D800?
Started by JackConnick ·
  • 29Posts
  • 29Replies
  1. Adam;
    You are basicly shooting a 21mm rectilinear f/3.5 lens. Yes, less distortion, but remember you can fix that very easily in LR.
    I'm just back from shooting the 16-35 in low light and am not impressed, it quickly jumps up to f4 and won't catch focus.
    Jack
  2. I'd have to believe that shooting the scene with the fisheye lens alone and then cropping the image to the same framing as the fisheye plus the kenko tele-converter would produce sharper results. A fisheye lens is the exact opposite of the type of lens tele-converters were designed to produce the best results with. The D800 allows you to choose several different cropped formats to shoot in and you could do that instead of shooting and cropping the full FX image.
  3. I'm with Alex on that - No need for a Tc with the Sigma 15 fisheye. You can get closer, croop or take the pic on X1.2 or Dx mode.
    The 105 works like magic with the Kenko 1.4 Tc. My 60 2.8 afs was hesitating with it.
  4. udi62 I thought the Nikon 60mm AFS wont auto focus with the 1.4x Kenko TC?
  5. udi62 I thought the Nikon 60mm AFS wont auto focus with the 1.4x Kenko TC?
    That's also my experience. The old 60 mm is working with it though
  6. On 10/16/2012 at 12:08 PM, JackConnick said:
    Well the answer is that it works out fine. On the Nikon D800, it seems to render CF/WA without the FE effect, and gives a little better reach to the shots. Sharp as heck, and the AF was quite quick, even without a focus light. I used a Nauticam 8.5" arcylic dome with a 20mm extension.
    _DSC7753.jpg by Pixel Letch, on Flickr
    Soft Coral & Gorgonian Fan by Pixel Letch, on Flickr
    Jack
    Hi Jack,
    Interested to find out, you say you used a 20mm extension, how did you determine that? Would a 30mm exntension work, or would the lens start catching the dome in the images?
  7. On 10/27/2022 at 12:47 AM, wildafrica said:
    Hi Jack,
    This post is now 10 years old and you won't always get responses from such old posts.  The extension is worked out from being the same as the thickness of the 1.4x converter.  If you look at the port chart you'll see that the Nikon 8-15 uses 20mm more extension with the 1.4x compared to the bare lens, this will also apply to the sigma.  Port chart here:
    https://drive.google.com/file/d/1FEKaahiDf_sCsXrlLMjWm_qEDLL5NerH/view
    Edited by ChrisRoss
  8. Hi Chris,
    Thanks for your reply. I took a chance that Jack may still answer ...
    I did go through the port charts but did not pick up on the Nikon 8-15mm differences! Thanks for pointing that out. Just need to find the 20mm extension now. Can't believe how expensive they are!!!
    Anthony
  9. Just saw this.
    It worked out ok on the D800, but wasn't my favorite idea. Zoom with your fins.
    It does not work on a D850, and I sold the Kenko a while ago.
    Jack
