Any Post-Haas Ike 300D housing reviews?
Started by chrism ·
  • 31Posts
  • 31Replies
  1. Any Post-Haas Ike 300D housing reviews?
    Anyone seen a review for the actual production housing anywhere?
    Chris
  2. No, but there are several (at least 4 I know of) people here that own this housing and can answer your questions.
    What do you want to know?
  3. I'm primarily interested whether the bulkhead placement has been a problem for anyone.......and any other idiosyncracies that bothered you about the housing.
    Also, any limitations of the 6" dome that you have experienced?
    And Ike, are there sync cords for Sea & Sea strobes yet?
    Chris
  4. My biased opinion is, of course, three "no" answers to chrism............
  5. Ike, as to the last question, I have heard rumors of plans for such a sync cord. True? If so, any idea when?
    Of course, the choice of housing hinges on the answer to this question, as I am not planning on changing strobes at this point in time.
    Chris
  6. You could always have Ike install Nikonos connections in the housing instead of the Ikelite version if you really like the housing and can't get the sync cords.
  7. Screw machine supplier has promised components since last December. Surely we will have this month............?
  8. I'm primarily interested whether the bulkhead placement has been a problem for anyone.......and any other idiosyncracies that bothered you about the housing.
    Chris
    I have been diving twice with the Ike Rebel housing and the bulkhead placement has never caused a problem.
    What kind of limitation are you referring to with the dome? The only problem I had was with the kit lens I had been using a Haze filter and forgot to take it off, zoomed all the way it would strike the dome. In my tests I tried both close macro shots and WA (As wide as the kit lens will go) and saw no problems with it.
    I have no idea about the sync cords, I use Ike's strobes. :)
    Dave
  9. I'm primarily interested whether the bulkhead placement has been a problem for anyone.......and any other idiosyncracies that bothered you about the housing.
    Chris
    On my first two dive trips I had no problems with the bulkhead placement. On the third it was allways in the way. The difference was that I screwed the cord in on the 3rd trip so that the cord was pointing away from the strobe instead of toward it.
    Only other idiosyncracy was on the first dive and the AV button didnt reach the camera button. But it was very easy to adjust it.
  10. I'd also be interested in anyone's experiences with this camera housing combination. How does is go with the kit lens, any problems with zoom function, what was the picture quality like with kit lens (and have you compared it to a better quality zoom/prime), what ports and lenses have you tried, and any other pros/cons that come to mind.
    I'm tending toward buying this housing but am still waiting for Aquatica's version to be reviewed.
    Ike, how likely is TTL support for the 300D in 2004? You mentioned in another post that eTTL was next after you sorted Olympus's TTL. And will the 300D fit in the promised 10D Ikelite housing?
    If someone here who has the IKE 300D housing could buy the Aquatica and write a comparison, that would be great.
  11. As you know Chris, I've done a bunch of dives with the production Ikelite housing. I'm working on a review but a few things have taken precedence over the last couple weeks.
    I noticed the sync cord hitting my regulator at times but after I re-routed the cords, I didn't find it to be a real problem. Like any new equipment, it takes a few dives to get things in a configuration that works best.
    I've put together a gallery of photos for each lens I used on my trip to Truk Lagoon. Each gallery has samples only from that lens along with the port used, etc. They're at:
    http://jaytreat.com/Diving/Canon_300D/Cano..._50mm_macro.htm
    http://jaytreat.com/Diving/Canon_300D/Cano...non_18-55mm.htm
    http://jaytreat.com/Diving/Canon_300D/Sigma_14mm.htm
  12. Thanks all - Jay and acroporas both mentioned sync cord routing.... I had just heard that placement of the bulkhead was an issue,.... any chance of posting a pic of what the routing that has worked for you looks like?
    Chris
  13. Thanks all - Jay and acroporas both mentioned sync cord routing.... I had just heard that placement of the bulkhead was an issue,.... any chance of posting a pic of what the routing that has worked for you looks like?
    Chris
    The difference is which end of the cord you plug in to the housing. One end of the cord bends up. The other down. It is easy for me to remember which end to use because as you can see the good end has a band around it.
    BAD: THe cord points up and is all in your face.
    GOOD: The cord points down is nice and out of the way.
  14. One thing I would like to ask is if anyone has trouble with the veiwfinder.
    I have trouble viewing the whole frame, even without my mask on. Makes it tough to compose the shot. This is the first SLR that I have used, so I have nothing to compare with.
  15. ahhh, thank you. picture is worth a 1000 words
    Chris
  16. And Two pictures are worth??
  17. Two pics? Bulk rate = 1500 words
  18. One thing I would like to ask is if anyone has trouble with the veiwfinder.
    No one has any comment about this? I guess I'm the only one with the issue... :)
    I have tried other masks, any suggestions? Just live with it??
  19. 300D and 10D have small viewfinders, this is one drawback of most current DSLRs (1Ds as a full frame camera should be better but I haven't tried one underwater). Using a 300D will be a bit different if you're used to a point-and-shoot. I've found I have sort of got used to using the 10D's viewfinder U/W, just by jamming my mask up against it.
