RX100 with Inon UWL-H100 Wide Angle
Started by SPP ·
  • 41Posts
  • 41Replies
  1. A follow up on my investigation about my Sea & sea DX-1G wide angle lens would work with a RX100II nauticam housing.
    So Interceptor121, what how much shuld the lens protrude after the thread ends? My Lens has a S&S proprietary bayonet mount, but this can be unscrewed from the lens, and I have a 67-52 step up ring that could be fitted instead on the original mount.
    As the RX100II now have a hot shoe, my biggest concern with the predecessor, this camera is now back on the radar. If I can reuse my WA-lens it would also help the budget ;-)
    42 mm is plenty however you will need to see how close will the lens be to the port
    What's the diameter of the thread on the lens?
