Subal or Nauticam?
Started by rumblefish ·
  • 92Posts
  • 92Replies
Subal or Nauticam?
  1. Seacam is not on my shortlist because they're more expensive ($ 5.500 price range plus another $ 1.680 or so for the viewfinder).
  2. @ kmsellin: Does Sea&Sea have a port locking mechanism all the way out to the Domeport ( trought the Extender)?
  3. @Wolf Eel
    No, they don`t have all the way out. You are all right there. I looks first port... But serious I think its really bad luck if it would twist the whole way. I mean you need to turn it like 90-120 degress to open. But It would be better if you could look it, then you are 100% sure.
  4. That D600 Nauticam housing looks great. Thanks for posting.
  5. No one's posted to this thread in awhile but I thought I'd pipe up with another 2psi. I recently was on a boat in Raja Ampat. I shoot D800 w/ Subal and there was another fellow onboard who shoots the same camera and has a Nauticam housing.
    I must say that I was very impressed with his housing, especially the simplicity of the vacuum seal that I guess his housing came with from the factory. I am always worried about my ports slipping off, and like someone else said here even though the extension ring locks that does zero in the case of the dome that's attached to it.
    I have had some niggling issues with my Subal. I got a housing from one of the first batches that arrived to the US and right out of the gate had issues with the fitting of the tray and usage of the controls (multi selector) I eventually resolved that issue by bending the tray rods and shaving down the backside of the buttons that control the multi selector and since have had no problems, but it was quite maddening to shell out that amount and have that issue haunting me for the first half dozen dive trips.
    Aside from that my housing has developed some corrosion, both in the smooth coating surface between backplate and housing and on the bayonet. The housing had to go back to Subal to fix the threading from one of the handle screws coming out of the body and so I had them repair the corrosion spots while they were at it. Living in Southeast Asia, I had to bring the housing back to the US where I bought it and then have the dealer ship it back and forth to Europe.
    I am strongly considering biting the bullet and buying all new ports and switching to Nauticam after spending a couple weeks on that liveaboard with the buddy who has the Nauticam housing. When I had my previous Subal (D300) I saw the quality and features coming out at Nauticam and it was laughable. I have to say that I've seen Nauticam improve by leaps and bounds ever since, which added to my few issues and the price differential has me considering making the switch.
    Well, I still have some life left in shooting my D800E so I have time to think about it. Sometimes the grass is greener when you look at other brands because you know the limitations and deficiencies of your own housing but not others until you try them.
    Those of you who have had Nauticam and Subal housings please update this thread with your more recent experiences. I think putting it all out there helps us and other shooters considering the same big ticket decisions all benefit from the sharing of firsthand information.
  6. I have an older Subal SLR film housing and numerous Ikelite housings., and new Nauticam and Aquatica housings. I used to be a Subal fan-boy, but I think that the quality and value for the money of both Aquatica and Nauticam have really improved over the years. My personal opinion is that Subal is coasting on their name an are no longer king of the hill. Between Nauticam and Aquatica, I think the fit and finish of Nauticam is superior, but Aquatica is over-built and sturdier. I have admired Seacam and Hugyfot housings (they seem very nice) but have no experience with them for comparison. Just my $.02.
  7. I have a Subal for my D800E and it was one of the first ones too. Had a right button issue on the multi selector and had Reef Photo adjust it for me. Also just had Reef install the Nauticam vacuum leak system on my Subal. The installation replaced the leak detector light with multicolored lights to indicate leak, no vacuum and vacuum. It turned out really slick.
    I dive with two buddies who have D800's, one has a Aquatica D800 and the other has a Nauticam D800E. I too am impressed with the quality of the Nauticam, it is designed well and has good ergonomics much like the Subal. I like the access to the iso button better on the Nauticam, but the Nauticam does not give access to the function or depth of field buttons as the Subal does. In comparing the D800 Aquatica, to the D300S Aquatica, it is better and they have improved. I like the feel of the main and sub command dials with the Subal, you can feel every click in change of f stop or speed. The Nauticam also has this feel but not as crisp with each change in f stop or speed, the Aquatica has the least feel with these changes. To me, the same analogy holds true for the shutter release lever feel. I can feel half shutter better on the Subal, second the Nauticam and finally the Aquatica.
    Elmer
    Edited by eyu
  8.
    I am strongly considering biting the bullet and buying all new ports and switching to Nauticam ......
    Why bother buying new ports, just get a Nauticam Subal port adapter and use your Subal ports on a Nauticam housing. After owning a series of Subal film and digital SLR housings over many years I switched to Nauticam four years ago and am still using my Subal and Zen Subal mount dome ports on my Nauticam housing.
    http://reefphoto.com/shop/index.php?main_page=product_info&cPath=80_148_149&products_id=4481
    http://reefphoto.com/shop/index.php?main_page=product_info&cPath=80_148_149&products_id=4486
  9. Elmer, the Aquatica AD800 DOES allow use of the "DOF" and "FUNCTION" controls. Are you sure you were comparing the correct housing?
  10. Elmer, the Aquatica AD800 DOES allow use of the "DOF" and "FUNCTION" controls. Are you sure you were comparing the correct housing?
    oops, my mistake..Thx for the correction.
  11. In historical order: Ikelite, Aquatica, Subal, Subal, Subal.
    The only problem I've had with the Subals is small spots of corrosion due to jamming in into the bottom.
    I treat these with clear nailpolish and keep strips of bath tub anti slip material on the bottom.
  12. Why bother buying new ports, just get a Nauticam Subal port adapter and use your Subal ports on a Nauticam housing. After owning a series of Subal film and digital SLR housings over many years I switched to Nauticam four years ago and am still using my Subal and Zen Subal mount dome ports on my Nauticam housing.
    Hi Grudge,
    I realize that these adaptors are available, but I would rather just make the complete move. Maybe I'll start with the adaptor until I'm 100% sure that I'm not going back before I get rid of all the ports.
    Eyu, great to know that the Nauticam vacuum seal system can be installed on a Subal and that it works well. I will look into this with my dealer!
  13.
    I previously had the Backscatter vacuum system on my Subal, it was without the lights, but worked well. I switched over since my wife has a Nauticam EM 1 and I wanted to eliminate carrying two different vacuum pumps. Another system to also look at is the Leak Sentinel. But the Nauticam is really a very cool installation that was done by Reef Photo
  14. Hi there,
    Years ago (2012) people have raised concerns with the visual complexity of Nauticam housings when looking inside (long mechanical links which allows some controls to be deported far away from original position on camera body).
    3 years later it would be interesting to know whether these have proven to be a weak point for anybody?
    Nicolas
  15. Nexus housings are really 1/3 the cost of Subal?
  16. Replying to Nicool's question - I have 2 Nauticam housings - for the Canon 7D (original) and 5D Mark III Sr. I had one lever slip out of adjustment and consistently scratch the top LCD screen of the 7D. I took the housing to my Nauticam dealer (Reef Photo) and they adjusted the control. Cost of labor was $40 USD. A little Nexus scratch polish and the LCD scratches were removed. My 5D housing is flawless. The design advances over the 7D are substantial.
  17. Thanks for these feedback megtooth, appreciated!
    I don't know how long you've been shooting both, but looks like the extra refinements of your 5D housing didn't make it less reliable :-)
    Any other feedback appreciated!
    Envoyé de mon iPhone en utilisant Tapatalk
  18. My wife and I both had NA-600D housings which have had Canon 600D, then 650D and 700D cameras in them for nearly 4 years now. Last year I sold one and bought NA-EM1 and NA-EM10 housings which are better for travelling. I still have one NA-600D housing which one of the back push buttons became misaligned when in transit from holiday. It was still water tight and I used it for about a year till I sent it off to have the vacuum electronics fitted at Nauticam Australia and they fixed it at no extra charge to the upgrade cost.
    The Nauticam housings are excellent and I must say the vacuum system gives great peace of mind. I took the EM1 and 10 housings for their first dives with the cameras fitted, no more empty housing dives every time you get a new port!
  19. Last year I bought my wife a Nauticam NA-EM1 housing and found it was hard to feel half shutter with the shuttler lever, the lever spring was too strong/firm.
    Otherwise the housing worked well and their vacuum system works great.
    Since then she has switched to a D7200 in a Subal housing, the half shutter feel is perfect and the housing works perfect.
    I am so impressed with the Nauticam vacuum system, I had Reef Photo install it is my Subal ND800 and her Subal ND7100 housing.
    This is our third Subal housing and once the body is fitted correctly, no problems.
    Elmer
    Alex, please dont take me wrongly. The world is "flat"... Some people buying expensive product (housings) in online shops globally, but then coming back to formal distributors, cause online shops running low margin business with no capability for after-sales support. And my point was not to say that Nexus better or cheaper than Nauticam. Just to remind public that there are other options available smile.png
    Yes there are many options out there. In this thread the OP limited the choices to two options so that the thread would be focused. Thank you so much for broadening the scope of this thread. I sell widgets, instead of taking pictures underwater you could buy my widgets. Please spend all your money on widgets.
