60mm vs 105mm macro
Started by seansrs968 ·
  • 34Posts
  • 34Replies
60mm vs 105mm macro
  1. The problem is that you would loose even more working distance adding a diopter on a 60mm.
    I was generally preffering the 60mm on a DX. The 105mm was more of a special case for me.
    If you want to use diopters. Then the 100/105 is the way to go
    /Erik
  2. So just stick to the 60mm with no diopter?
  3. Diopter on 60mm is no point in doing.
    I had the 60, but returned it for a 105. As i found out it wasnt what i wanted for the very smal stuff.
    Sendt fra Samsung Galaxy S2, via Tapatalk forum app.
  4. A diopter can be useful on a 60 mm with an APC sensor camera.
    60mm with 1.4 kenko TC and +5 Aquatica diopter.
    Edited by johnspierce
  5. I think the answer is now crystal clear - take both 60 and 105
  6. I think the answer is now crystal clear - take both 60 and 105
    That is the way to go :evilgrin2:
    Get some wetdiopters and TC:s and you are set!
    Then you have shifted the problem from packing for the trip to the Dive boat
    Edited by E_viking
  7. Heartily concurr with observations on 60 mm and 105mm
    I use both, but because I love shooting skitty fish up close i.e. blennies, gobies, and hawkfish...105mm is my weapon of choice...... all the time
    I have the 60mm too....use it more on night dives...or of the viz is particularly bad.
    Do not use either lenses with TC's or dioptres....yet ;-)............but would def,. consider the Subsee rig in the future....
    Happy shooting!
  8. I am a 105 guy. I don't take the 60 anymore. However, I dive in good vis. I always have a subsee +5 and +10 available.
  9. I've been playing with a Subsea +10 on my AF-D 60 micro and found it almost impossible to get focus or decent light. If there's even slight surge, forget it. The lens has to nearly touch the subject. I've been thinking about trying it with a 1.4 tele, which will work with the 10-17 as well. Haven't got a single keeper so far. +5 might be easier.
  10. I shoot the +10 and +5 on a 105. My process:
    1-Camera set to focus priority. (The camera will not take a shot unless it is in focus)
    2-Camera in continuous focus mode, no delay setting
    3-Strobes next to and parallel with the port.
    4-Have buddy shine a light on the subject (If Pigmy shine from behind. The pigmy will turn away from the light toward the camera)
    5-Get closer than minimum focus then slowly back out until the camera gets focus and takes shot
    In surge it still rately works and, yes, the +5 is a lot easier
  11. beautiful shot!
    Would a +10 work in combination with a 180mm macro (this has a minimal working distance of about 50cm.)
    Best regards,
    --Rob
  12. I shoot the +10 and +5 on a 105. My process:
    Good ideas. I just got the +10 and I am looking forward to playing around with it.
    I really like the pic!
  13. Man this is getting so complicated. So I might buy a 100 for the trip. Should I even bother packing my WA for Anilao?
  14. Beatrice has good wide angle with soft corals, but usually shoot macro in Anilao.
