How many controls do you actually use on your housing?
Started by petern ·
  • 27Posts
  • 27Replies
  1. So I was wondering, with new cameras there are so many options with
    setting to do a wide range of image capture, as a result housing
    manufacturers provide nearly 100% control access. But how many do you
    actually use? I know some will say everyone but what would be the most
    commonly used and do we need full access to all the features that the
    camera has while underwater. If you shoot in full auto then you could get away with one, shutter.
    Excluding professional image makers, Imagine if you had a choice of housings that had less function yet where a lot less to buy, would you still buy
    the top of the range or really think about what you used and purchased the
    same make/model with fewer controls?
    When I worked with film, you know that 3 foot bit of plastic that had perforated holes down both
    sides, I had 5 controls on my housing and that just about covered every thing I needed
    to adjust and capture the image. So would you use 20%, 50% or more of the camera function
    during your average dive? GoPro has two and a limited menu.
    Also could you cope if a photo comp allowed to pre set your setting , which you gave the organisors pre dive, then restricted you to shutter speed, aperture, strobe adjustment and preview.
    Hmm lets see where this goes... :)
  2. On/off
    Red filter
    WB
    Focus (lock)
    Record
    Menu (just in case)
    Play (for deco stops)
  3. On/off
    F/Stop
    Shutter speed
    Shutter
    I review underwater and occasionally expand the view.
    Shooting Raw I see no point in anything else.
  4. I use regularly:
    Aperture, shutter speed, on/off, flash up and down, focus modes, AF-ON, shutter release, playback, rear dial, OK button, +/-, ISO, LV, Video Start/Stop, shooting modes (single shot/multi shot/ 2 second delay), mode dial WB, info, erase, lock photo, zoom in/zoom out, menu button
    lens release when back on the boat.
    So, all of them pretty much.
  5. I agree with Alex. I've found a use for just about every control on the housing.
    But it does depend on the type of photography you do. If you just want to take ID shots (of fish, nudibranchs etc) with a macro lens (and lots of people enjoy this type of underwater photography) you could probably get away with a shutter release and TTL.
  6. I use regularly:
    Same for me except that i don't need 'shooting modes' (Single, multi/2 s delay), 'mode dial WB' (i'm shooting RAW, but for video necessary), Flash up/down (electrically wired strobes) and AF-ON (via the shutter release), but i do use AE-/AF lock occasionally, the AF-/M focus selector and the P/A/S/M button
    But the need for full accessibility is with me also very depending on the type of diving. During wreckdiving at the Northsea with a visibility sometimes of less then 2m at average depth of 30 m with a lot of current, some buttons become more relevant then others. Absolute necessity to me: ON/OFF, aperture, shuttertime, ISO, focus modes, rear dial and auto- or manual Focus and shutter release.
    I think that's about it.
    Edited by Udo van Dongen
  7. Alex makes a goood point. it really depends on what king of shooting you do.
    As a macro guy, shooting AF and sTTL and focus release shutter priority (camera takes pictures only when in focus) I really only change the F/stop and shutter speed. In particular, taking super macro shots with a +5 or +10 diopter, how many options on the camera does one have? It is all about your position vis a vis the subject and strobe placement.
    And no, one can't make money with these kinds of shots but that's not my intent.
    Regards,
  8. It really depends what settings I forget to turn on before I get in the water! Whilst there are many i dont nornally use, I am sure I would miss any if they were removed
    Mainly trigger, on off, af lock, review, af selector, aperture, shutter speed.... live view which i wish was not there as i only press it by mistake and quite annoying when everything goes black throught the view finder!
  9. Controls used rather depend on whether I set i up properly before I got wet !!! Having full menu control has saved the day a couple of times.
    Modern cameras are so much more complex than a manual focus film SLR.
  10. Controls used rather depend on whether I set i up properly before I got wet !!! Having full menu control has saved the day a couple of times.
    That's exactly what I was going to answer. I'd really hate to scrap an entire dive because I forgot to set an unmodifiable control right. Kind of like pulling the lens cap trick or something....especially if you use the same camera topside as below, as you might be using completely different setting assumptions between dives.
    Edited by rtrski
  11. My experience is that if I don't have access to a control, I immediately need it :laugh:
    Despite a reticence amongst photographers to admit it, modern cameras offer a great deal of functionality that produces better pictures. Not being able to access it tends to negate these advantages.
    Adam
  12. All of them. I wish I could access single/continuous shooting modes but I can't on my Hugyfot.
  13. Only thing I missed is lens controls. Canon 100mm lens has a limit switch and af/mf switch. Both are a pain to forget
  14. I use aperture, shutter speed and ISO (and the trigger!) on every dive. I usually but not always change my AF points, press play a few times, use INFO to check my histogram and move between using the AF-on and the shutter for focussing.
    I use set and live view when taking video, and the rest occasionally as required. I don't think I've ever touched the stupid Canon "picture styles" button, and I rarely touch the mode dial out of M.
    Being able to get to the MF/AF slide on the lens would be handy - I've lost two dives to knocking this into MF when I inserted the camera into the housing (presumably) and it was very frustrating both times.
    I was reading the EasyDive housing review which seems to be an interesting way to cut down on housing upgrade costs...except you lose a bunch of functionality through moving to electrical control. It seems there are pros and cons to every decision.
  15. Also could you cope if a photo comp allowed to pre set your setting , which you gave the organisors pre dive, then restricted you to shutter speed, aperture, strobe adjustment and preview.
    to make the analogy to car racing: to my opinion it would be something like an old-timer race with crippled modern cars, not something i'd be interested in.
  16. As I mostly shoot stills using manual settings I use very few controls - generally that is (shutter release/aperture/shutter speed/ISO/review/info) - but then if I shoot video using the dSLR then the number goes up. And I have used other controls depending on the circumstances and what I'm shooting. The problem is that whilst some controls get little use, at times they may be essential. If I had to use a minimalist housing I would shoot manually with the 'bare essentials' covered as I first stated.
  17. All of them. I wish I could access single/continuous shooting modes but I can't on my Hugyfot.
    I don't know which camera you use, but on my Nikon D7000 you can set the camera to CL (Continuous Low) and adjust the settings from 1 to 5 fps in the menu. Not as convenient as a dedicated button, but at least you can still switch.
  18. I use a good few of the controls but not on every dive and you can be sure ‘Murphy’s Law’ would come into play if I had a housing that excluded some of them as eventually I would feel them wanted, so with that in mind I’d rather a housing that allowed the use of all camera functions.
  19. I don't know which camera you use, but on my Nikon D7000 you can set the camera to CL (Continuous Low) and adjust the settings from 1 to 5 fps in the menu. Not as convenient as a dedicated button, but at least you can still switch.
    D800. I probably need to read the instruction manual but I'm only half way through the manual for my newest car, which is a few months older. (I've only just got to the particulate burner!) Thanks for the heads-up!
    Edited by John Bantin
  20. I use pretty much all of them. However, the most frequent ones are shutter release/aperture/shutter speed/ISO/review/info
