BMPCC underwater filming setting
Started by edmond320 ·
  • 51Posts
  • 51Replies
  1. Hi all,
    Where I can see some 7-14mm or 8mm BMPCC underwater clips?
    With that crop factor I guess that the Fisheye shouldn't be too bad.
  2. Hi edmond
    My review is online now, but it is way too long to post here on the forums!
    I've posted an example video in the sharing forum and the review can be seen at www.viewfromtheblue.blogspot.com
    Cheers, Simon
  3. Hi Simon,
    Very nice report !! Thank you so much for your sharing and hard work !!!
    Edmond
    Edited by edmond320
  4. Edmond, you taken yours to water yet? If so, how are you finding the buoyancy?
  5. Yes, I have been playing with it in my pool during weekend. I took out the long carbon float arm and leave the short and fat one.
    It will be just slightly negative, all together with the Ninja 2 housing, and my DIY platform.
  6. I've just (literary) come back from the pool with my and some precise scales
    -1.1790kg negative (in fresh water) with no floats
  7. hi Edmond
    Could you post some photo of your diy plate with some detail?
  9. 13739379055_b50224b6f7.jpg13739472473_e09f3fcc5c.jpgl13739812764_34295fd479.jpgl13739789744_6646596493.jpg13739419963_a2733ee764.jpgl13739741174_45dcddf490.jpg
  10. Hi Davide,
    Hope the pictures can self explain what I did for the BMPCC and GH-3 housing.
    Those platform are made from POM material.
    Edmond
  11. Thank you Edmon you gave me a nice idea :lightbulb:
    Only problem is finding a plate of delrin, I saw only tubes and it's very expensive. Maybe PVC works the same.
    Until now I used cheap chinese tripods :alien: I have a small project in spring water filming the surface form the bottom. I find them for 15€ and in spring water they last a lot but I like your design.
    Byeee
  12. Thank you all for your suggestion. Actually I saw that here in Italy on Ebay there are some deals: 40$ for a plate 500x500mm and 10mm thick.
    I have to check in Germany, usually they have good prices on mechanical related things... of course 4$ it's a steal :)
    What's the minimum thickness for this application? I guess 6mm or 8mm are enough...
  13. Hi,
    For mine is 9mm. I think it will be better to have 10mm.
  14. I have made a tripod set up for my compact rig using few ultralight parts it is not difficult and works a treat
    Looking at your set up you need to consider that shorter legs are actually better to avoid your rig to take off and also that whilst 3 points will always be in balance 4 won't and you may run into trouble setting it up on the bottom. A 3 legs table never wobbles a 4 legs does at the minimum misalignment
  15. Thank you for your comment in advance.
    This is not my first time to use this kind of setup. I have been using this setup to shoot underwater video for 4 years.
    I know very well how good it is, to use 4 legs better than 3 legs, and a longer legs than short legs.
    To my understanding, more legs, more stable. Most of the chairs we are seating have 4 legs. The dentist chair that I am seating everyday to treat my patient have 5 legs. It just more legs you have to adjust to find the balance, but once you balance it, it is more stable.
    To give you some idea how good it works, you can take a look at my video below.Those magnified shoot on Harlequin Shrimp (2:50)can be so stable by using 4 legs platform to film, and so as all the other shoot.
    Edmond
  16. Good video
    That does not make any physical sense though
    Chairs have four legs as you dont want to sit on a triangle as your bum is squared but usually have adjustable feet to compensate
    Three point of contact always balance on the same plane four don't. Before mankind introduced levelled floors all chairs had 3 feet as they steady on an uneven floor
    That is why manufacturers sell camera tripods and not quadripods
    But if you are happy with the additional time to balance four legs good for you
    Edited by Interceptor121
  17. For your information,edelkrone just release a pocket stand like this :
    picture from edelkrone
  18. Quadpods are more stable and stronger but can take longer to set up.
    Tripods are still stable, and are a lot quicker to work with.
    You've got some stunning results Edmond, which us really all that matters ;)
