Z240 erratic behavior after 3 year - expectable?
Started by Nicool ·
  • 21Posts
  • 21Replies
  1. Time to start at the start again and go through all your steps, from camera settings, to strobe settings and all equipment connections.
    *Check camera flash setting. Make sure it isn't set to Red Eye or something odd that will affect sTTL sync.
    *Assuming a possible issue with optical cables, did you check both ends of cable?
    *Have you removed the ACC magnet to see if it is corroded and the possible issue?
    *Check over all camera settings with others using the same. Lots of info on your camera here- http://wetpixel.com/forums/index.php?showtopic=52608
    Jim.
