GH4 Ikelite housing and external monitor?
Started by ken_keeler ·
  1. Hey guys,
    I know this topic has been brought up in the past but, does anyone know if there is a was to hook up an external video monitor to the GH4 Ikelite housing. Ive done some research and unfortunately most of it seems like its a DIY type of thing.
    I Nauticam the only ones that give this option with the bulkhead?
    Has anyone tried modifying the TTL bulkhead on the Ikelite housing?
    If anyone has successfully added a monitor i would love to here how or see pictures. Thanks!
  2. I installed HDMI bulkhead connector for Ikelite Canon Mark III
    Custom%20port%20for%20Ikelite%20housing%
    More pictures details is here
    Same way you can install HDMI bulkhead connector for Ikelite GH4 housing.
    Difference is only Micro HDMI right angle connector on the end of the bulkhead connector, and better to use bulkhead connector for 16 mm hole, with security nut (inside of the housing)
    Underwater%20Dive%20And%20See%20USB%20Mi
    Alex,
    Edited by combatalex
