Nauticam NA-A6000
Started by brannon ·
Nauticam NA-A6000
  1. Does anyone shoot with a Nauticam NA-A6000 housing? If so, do you like where the shutter release button ? Is it easy to press, to get to using a tray like the flexitray, etc? The Sea and Sea housing for the Sony A-6000 has a trigger style release. I was wondering what the pros and cons were.
  2. Does anyone shoot with a Nauticam NA-A6000 housing? If so, do you like where the shutter release button ? Is it easy to press, to get to using a tray like the flexitray, etc? The Sea and Sea housing for the Sony A-6000 has a trigger style release. I was wondering what the pros and cons were.
    the shutter/trigger is ok....but in my opinion , not for a $1650 housing!....(when the EM1 cost 1850 and has flexitray and 2 triggers ! )
    Nauticam fix this ( partly) with a special solution to be used with a flexitray - cost only $60
    http://scubasupply.nordicshops.com/product.html/shutter-release-nauticam
    http://reefphoto.com/shop/index.php?main_page=product_info&products_id=8394
  3. I've been using the Nauticam housing and flexitray without adapter for over 18 months and have no problems in either cold or warm water on over 400 dives
