Complete Lens Bag
Started by james ·
  • 59Posts
  • 59Replies
Complete Lens Bag
  1. I've tried the 24-85G underwater with my Nexus rig using both a dome (4") and a flat port and had very good results. I also have the D but it's very hard to get a Nexus ring on that lens to provide zoom capability. I did not use a diopter with the G lens although I had a wet diopter for the flat port. My advise for G users is to get a 67-62 stepdown ring, a 62mm lenscap and install the combination permanently (except the lenscap while shooting, of course!). The stepdown ring will protect the fragile plastic threads and allow the use of standard Nikon diopters if you like. No vignetting occurs.
    Problem with either of these lenses is that you won't get the magnification you think you will because of the working distances. If you are expecting 1:2 or better I think you'll be disappointed. Good for fish portraits. I've used it for sharks and for frogfish.
    I used a Tamron 28-75 with the Aquatica/Kodak on the last trip behind the Aquatica 8" dome. It lacks the close focus of the Nikon 24-85D but it worked (quite well, in fact) in a pinch. I've also been looking for a midrange zoom with decent macro performance for the same reasons Robert has. I think the 24-85 is an OK solution using DX sensors but full frame complicates matters. I've looked on the Canon side and it seems that Canon doesn't offer midrange zooms at all with decent close focus capability. Tamron makes a 28-135 with OK close focus but I have no experience with it. The long end may provide enough working distance for full frame and reasonable magnification.
    Eric, you prefer the 17-40 over the 16-35? The 16-35 would appear to have the edge in autofocus because of the extra light but the extra length and lighter weight would be nice on the 17-40. How does the 17-40 AF work underwater using your 1D* bodies?
  2. I used a Tamron 28-75 with the Aquatica/Kodak on the last trip ...
    You've been holding out on us big time. :)
    What do think of this setup? Where are the photo?
  3. I too tried the 24~85 f2.8~4 underwater and was disappointed to find that it simply wasn't as sharp as I wanted. I ran it as a macro zoom on an S2Pro behind a flat port and the camera proved to be very capable of showing up weaknesses in the lens. A real pity because it is potentially a very versatile lens.
    Dream kits do depend on what you shoot and where you shoot, I tend to favour 50/60 macros in our murky temperate waters. I really like the 12~24 and despite having switched to Canon still keep the 12~24 just in case ......
  4. Now getting a D70 in Ike housing set up... thinking an early bag is just a Nik 10.5 FE / Nik 16 FE / Nik 60 macro is good (these 3 go in one dome + 1 flat port)... go to rectilinear WA lenses with another port later, and retaining the option for a longer macro, too (Sigma 150 f2.8 HSM, if supported, with its port, later?).
    I have the 10.5 and 60 (Nik) already.
    For long lenses: the Sigma 100-300 f4? Sig 70-200? Nik 70-200? (both sigs have integral focus (HSM), the Nik has internal focus (AF-S) and VR). With 1.4x TC? Still thinking...leaning Sig 100-300 w/ 1.4X TC...for value and reach.
    What thinkest thou ... if anything?
    And of course a D2X in a Subal or Seacam when the early adopters move on ...
    All the best,
    Chris
  5. Hi Chris, I have the 70-200mm HSM Sigma it is a very sharp lens, and pretty fast focusing, but if you can afford the Nikkor with the VR please do, I had some jam up with my Nikon D100 and the Sig 70-200 (not the S2pro nor the N90s) it seize the camera and you have to shut every thing off and reopen the camera, (real drag when your shooting cavorting right whale). I had four customer complains for this problem, exchanged the lens and never heard of it anymore, please make sure you buy with a good return policy when you do. aside from that perk I had total satisfaction from this lens so far.
  6. Hi Chris....I'm hearing good things about the Sigma 15....
    Karl
  7. Karl,
    Yes, the Sigma 15 FE looks good ... but the Nikon 16 FE fits behind the same Ike port as the Nkon 10.5 FE (the Sigma doesn't, according to Ike's chart) .
    And...I just bought (yesterday) a lightly used Nikon 16 FE for less than the new price of the Sigma. Gotta be quick!. As I save the cost/bother of an additional port with this lens, this choice is doubly appealling. So my UW lens set up looks like 10.5FE and 16FE, with a 60 Nikon for macro. Fisheye man. And I get to remain a Nikon glass snob, for at least one more lens!
    In the next year or two, I'll think about longer macro, probably Nikon 105, or Sigma 150 -- I look forward to hearing more about the Sigma, and hope that it fulfills its promise and that Ike will figure out a way to house this HSM macro lens. Comments?
    After that, when the wallet has stopped smoldering, I may add recitlinear WA lenses (Nikon 12-24 or Sigma 10-20 plus Sigma 14?). Assuming I'm still in an Ike housing at this time, the Nikon 12-24 uses the same port as the Sigma 14 ... which can also be used with the 60 mm ... keeping my dive clutter at a somewhat less unreasonable level.
    Then it'll probably be time to look at upgrading the body/housing...to the D3Z with an unobtanium housing featuring a Plusgrand IMAX sensaround viewer and quadruple sync bulkheads supporting x-TTL.
    Landwise...
    Jean, I like the look of the Nikon 70-200, with AF-S and VR, but it is probably too dear for me. So, when I can afford it, I may try the 100-300 Sigma + 1.4X TC (HSM, but no OS) -- only a stop slower, reputedly sharp, longer, and less money. This seems like a more useful lens than a 70-200 for me. Thanks for the heads-up on the compatibility issues; I will read up on it and test carefully.
    Thanks for all the help!
    All the best,
    Chris
  8. Just saw this thread pop up and that james started it a while ago.
    I couldn't help but notice you have a 70-200mm canon now you swapped over. (from UWP)
    I was considering buying one too as it is a great land lens too. I am not sure Sea and Sea houses it though .. I could be way wrong there, but that would justify buying it if it could be housed as well. I would also like to know how it acts underwater .. even though we have different cropping i don't think I have even seen anyone discuss that lense in underwater use .. maybe I just haven't looked.
  9. Chris....your logic is serving you well :D;)
    BTW....I use the 80-400VR topside and it's an awesome lens IMO....lots of fun to use and very sharp....
    Karl
  10. I'm having difficulty with the latest luggage restrictions. Particularly with the 50# limit on checked bags.
    I would like some recommendations on wht you would take to the Galapagos for a week... I'm shooting a Canon 5D and so is the wife so we can have 2 rigs topside...
    Here are my choices (all Canon):
    85mm f/1.2L - This is fast becoming our favorite topside lens
    14mm f/2.8L USM - This is my UW lens so I'm takin' it
    100mm f/2.8 Macro USM - The wife's UW lens so this one is coming too!
    24-105 mm f4 L IS - Nice range but maybe too slow?? A little soft?
    300mm f/4L - Heavy but... what about those critters...
    135mm F/2 L USM - Fast lens. Great for Bull Riding shots!
    EF 1.4x II Teleconverter
    The 1.4x fits on the 300 and the 135
    So as you can see if I bring all of these plus two bodies plus.... plus...
    Is the 24-105 worth bringing? The 300 seems to be a definite front runner.
    Current thnking is that for land the 300 would be mounted on one body and the 85 on the other... bring the 1.4x extender.... The 14mm doesn't weigh too much to pack to the mountains
    Or do we bring the macro? It is a nice 100mm lens too.
    Tripod seems to be way overkill. Monopod maybe though.
    Oh yes, we will be going to machu picchu the week before the dive trip.
    I'm soooo confused :)
  11. Hmm, my Lowepro Photo Trekker AW is loaded with the following when I go on trips...diving or otherwise:
    Canon 5d and 10d
    Sigma 15mm FE
    EF 16-35L
    EF 28-105 f3.5-4
    EF 50mm F2.5 Macro
    EF 100mm F2.8 USM Macro
    EF 100-400L
    Tamron SP 1.4 TC (same as the Kenko 1.4 Pro)
    I may add the 70-200 f4L (non-IS) but do dream of the 500f4L too! :)
    Stu
  12. The 1.4x fits on the 300 and the 135
    The 135mm is said to work very well with both the 1.4x and 2x teleconverters. The latter would give you a 270mm F4.0 and could make the heavy 300mm F4 redundant.
    Bart
  13. Hi Folks!
    Interesting thread ... but I am still in the dark on my choice:
    My gear: Nikon D200, Aquatica housing
    I will be going to the US in 2 weeks and I do not have any UW lense yet. My budget allows 2 lenses and I was thinking about the following ones:
    1) 60mm Macro
    2) 105mm Macro
    3) Sigma 10-20mm
    4) Tokina 10-17mm FE
    Option (1) is very certain, as I am quite a bit into macro and the water here in Norway gives plenty of small stuff. Unfortunately I do not have experience with any of these lenses. Most of you talk about the 60mm as the absolute standard lense which gets plenty of use for fish portrait and medium size critters. But what is medium size really? Is it worth to invest into the 105mm macro then to go smaller?
    Ok, to add complexity to this whole topic: I will be going to Egypt for the wreck tour in November. So a wide angle should be in my bag. Then, option (3) or (4). Many comment the fish eyes as very hard to use for beginners, which I am. Is option (3) then the better choice to start with?
    As I said, I can only affort 2 lenses right now. Ultimately I think I will go for all of the ones I mentioned. But htat will take some time.
    Hope anyone has some tip for me
    Cheers, Wolfgang
  14. a great job of camouflaging the tell-tale bumps and bulges of a bag full of camera gear
  15. Anyone thought to try the sigma 8-16 in place of the sigma 10-20? i have tried it on land and i am impressed - think it would make a good UW lens.
  16. What do you think of the Cotton Carrier StrapShot?
    This looks like the PERFECT solution for when I want to go for a hike or carry my camera backpack with my full kit...BUT have my camera out and ready for access to get those once-in-a-lifetime shots.
    I was looking at getting the Capture Clip before what I like about the Cotton Carrier StrapShot is that I can take the camera out with one hand. It's another good thing that they have a safety tether in case my hands are slippery. (Gets humid here.)
    Anyway, will find out next month when mine arrives. Placed a pre-order to save $20 and got free shipping!!!
    What do you guys think about the StrapShot?"
  17. Has anybody used the 14mm Canon 2.8 prime lens for UW photography? Any samples?
  18. Has anybody used the 14mm Canon 2.8 prime lens for UW photography? Any samples?
    Stephen did a test a ways back. You can find it here.
    Also, Liz Rogers has posted some pics here and on her website.
  19. Hi everyone..
    Sorry for being the 'New Guy' jumping in with a question right off the bat!
    I have a favour to ask anyone shooting Canon DSLR in an Aquatica housing, I need a measurement (mm) from the front of the camera lens bayonet (silver metal part) to the front of the housing port bayonet (the flat face your port sits flush against).
    I am a long time underwater DOP here in Australia and I build a heap of my own custom housings for RED, 3D and other oddball cameras. I am experimenting with a few off the shelf port options with one of my creations (happy to post photos as I move along).
    I am on MKIII of my RED housings, building this one specifically for the Tokina 10-17mm fisheye which I love the look of underwater.
    If anyone can help please let me know..
    Thanks in advance.
    Dean Cropp
    www.accessallangles.com
