Underwater Monitor for Panasonic GH5
Started by adamtaylor ·
  • 56Posts
  • 56Replies
  1.
    The image flip can be turned off and it's not intrusive. I haven't had it flip on me unless I was tipping the camera to the extreme. How you describe your use of the camera is exactly why I have it set this way. It's really easy to adjust in this orientation.
    I have the camera's built in screen turned off and I can get to the buttons and dials just fine. Attached are some bad iphone pics to give you an idea. I have the tilt adjust in several positions. It adjusts easily underwater. Positioned behind the camera it's less of a sail in current, but it still creates drag.
    Thanks for the images, really helps appreciate scale.
    Looks like an extra long clamp, and that the monitor can swing into a few different orientations easily.
    Adam
    Regards - Richard
    Kind of what I recall from the marketing materials, but it does seem to tuck in tight behind the camera. Must feel like a brick underwater without the floats ;-)
    Can you still access the top and front buttons / dials easily?
    Am thinking cost wise I will going for one of the other two...
    Regards,
    Adam
  3. I'm about to pull the trigger on either the DNC-7A or the DNC-5A. Any reccomendation as between the two? Phisically, they seem to be roughly the same size, with the 7A being neutral and the 5A 300g negative.
  4. I also have the nauticam small hd setup. I do like the idea of flipping it upside down. Never thought about that before.
    I also like the nauticam setup and personally don't know how I did it without it in the past. The focus peaking is a huge selling factor for me. I also find the color to be pretty good as well. It is very easy to use as well with different modes depending on what you want to see. You can flip between them with 1 button push. There are some cons however that I think Nauticam could address.
    -The HDMI cable is very finicky. I always travel with a spare cable and bulkhead.
    -The housing is larger than it needs to be.
    -The shade is an addon that is ridiculously priced. But I do like it. Especially for shallow water.
    -Dustin
  5. I agree, for the price Nauticam charge for external HDMI cables, they need to be more than 'normal' HDMI cables with added bulkheads...
    I had the cable on my NA-FLAME dead on arrival, thankfully Nauticam replaced it FoC for me, but I was quoted in excess of £320 for a replacement. Which is way way too much
  6. The problem is that Nauticam uses a micro HDMI plug to connect to the bulkhead, which is a flimsy connection by definition... DiveandSee uses a mini HDMI, being quite a bit more solid in my view.
  7. So what's the conclusion? The dive and see 5 inch or the small HD 5 inch? Is the colors really not reliable as I read with the dive and see?
    And how much problems does the small HD mini hdmi cable give u underwater?
    I actually like the features of the small HD more but having usable cables is priority nr1
    Skickat från min VTR-L29 via Tapatalk
  8. So what's the conclusion? The dive and see 5 inch or the small HD 5 inch? Is the colors really not reliable as I read with the dive and see?
    As I will occasionally use the monitor topside I have opted for SmallHD 502 (so I can send up a surface feed in the future).
    Ordered the housing and just waiting to see if there are any Black Friday / Cyber Monday deals for the monitor.
    Will comment after I have tried it out.
    Regards
    Adam
    Sent from my SM-G903W using Tapatalk
    Regards - Richard
    How are you liking those Keldan lights? Do you use ambient and spectrum filters?
    Thanks for all these input and sample pics. As i'm considering getting a monitor too and this thread has helped me weigh towards the Small Hd 502
  10. How are you liking those Keldan lights? Do you use ambient and spectrum filters?
    I do like my Keldan's (They are the CRI variant), a love soft beam of light, although I'm waiting to upgrade the bulbs to 10,000lm once Keldan release newer ones (they are currently 8,000lm on the market and mine are 5,000lm) That is the amazing thing about the Luna 8 / M8 series - you can upgrade etc
    I've got the cyan leds also (so act the same as the filters you mention) for shallow water stuff, but find they aren't powerful enough (even thou they are more powerful than normal lights with filters fitted) I prefer at the moment, to dive when it isn't so sunny and outshine the sunlight with lights, and just stick with powerful lights and a preset white balance.
    I've tried a range of 'red' filters with my GH4 and I always found it a fudge, as once you fit it, you are locked in to ambient filming.
    Keldan are currently demoing a external filter to fit the Nauticam WWL-1, which you sandwich between the wet lens and the flat port - that could be a good compromise.
  11. Keldan are currently demoing a external filter to fit the Nauticam WWL-1, which you sandwich between the wet lens and the flat port - that could be a good compromise.
    I have tried the same on my RX100 setup. I just cut gel filters (one for blue water one for green) and fit them between the WWL1 lens and the port. Not the easiest solution but it works and the filters are so cheap that you dont care if you loose it when you remove them. I carry couple of them in my wetnotes and just replace it if needed.
    Any links for the Keldan ones?
  12.
    This basically mirrors my own experience. Cyan lights, or cyan filters on lights, just don't have sufficient light output to make a difference. And honestly, I haven't seen any footage below 10-15 meters that's been white balanced to the ambient light that looks all that great -- you just lose too much saturation and color contrast/vibrance. Better to do what the still photographers do and light up the foreground with warm artificial light while keeping the water column it's natural blue or green color rather than grey.
    (I actually would love to be corrected though -- anyone have samples of ambient light video below 10-15m that looks great?)
  13.
    Thanks for the feedback. I now plan on getting the new 2018 Keldan 8x. I'll try them with the filters in my Palau trip this Jan if I can get them on time and see how they go.
  14. Thanks for the feedback. I now plan on getting the new 2018 Keldan 8x. I'll try them with the filters in my Palau trip this Jan if I can get them on time and see how they go.
    I have two Keldan Cyan filters laying around in my "unused toys" box which I am thinking of selling. Let me know if you're interested.
  15.
    Thanks Bub, I was planning on getting the new 2018 filters which are supposedly less scratch prone. Did you find any good use for them or try them with the red spectrum filters from Keldan?
  16. Thanks Bub, I was planning on getting the new 2018 filters which are supposedly less scratch prone. Did you find any good use for them or try them with the red spectrum filters from Keldan?
    See my post from July here:
    http://wetpixel.com/forums/index.php?showtopic=58939&p=386266
    I did not find them all that useful. They absorb way too much light.
  17. As I will occasionally use the monitor topside I have opted for SmallHD 502 (so I can send up a surface feed in the future).
    Regards
    Adam
    Finally getting my new addition in the water once the Marina closes tonight.
  18. Finally getting my new addition in the water once the Marina closes tonight.
    Nice! Just ordered my 501 as well. Did you find any deals? Any plans to flip it upside down? That feels like it would smack me in the face being that high hehe. What applications do you have in mind for a surface feed?
  19. Nice! Just ordered my 501 as well. Did you find any deals? Any plans to flip it upside down? That feels like it would smack me in the face being that high hehe. What applications do you have in mind for a surface feed?
    The extra long Nauticam clamp did make it sit fairly high, but I could flip it down, and also flat so I could look straight down while shooting macro.
    Will have to figure out how to turn off the auto rotate on the screen as certain angles flipped the image on me...
    Battery died about 70 minutes into the dive. It was relatively cold water at +/- 42F and I had played with it out of housing and let sit for a few days. I did expect better battery life with 2 connected, but as I didnt start with full charges will reserve judgement.
    Ended up being a night dive which isn't ideal for learning new camera stuff, but saw some cool critters. Had to be selective in what I focused on as the moment we descended there was a seal using our lights to hunt fish.
    Have not purchased the surface feed kit yet, but will in future which is why I chose the 502 over the 501 model. Will use at for live-feed at conservation / education events where we have interpreters on shore with some hardy diver-collected species, and likely some salmon stuff in streams and rivers.
    Would love to do live-feed from a glass sponge reef, but given the depths it may not be feasible.
    But speaking of sponge reefs I look forward to swimming the edge of reef with camera held below pointing diagonally back over the reef. Should be easier to frame the shot with a monitor pointing up [emoji6]
    As I am in Canada there were not many options for purchase. I watched prices and purchased online from B&H on Cyber Monday. Got the kit for the same price as monitor alone from a Canadian site...
    Regards
    Adam
  20. Nice! Just ordered my 501 as well. Did you find any deals? Any plans to flip it upside down? That feels like it would smack me in the face being that high hehe. What applications do you have in mind for a surface feed?
    Curious why u would flip it upside down..
