Best wide angle lens for Nikon D850 in Nauticam housing
Started by SMY ·
  • 33Posts
  • 33Replies
  1. I love my sigma fisheye but Im looking now for a wide angle lens for my Nikon D850 in Nauticam housing. Which one do you prefer or do you recommend...and with which port?
    Regards, Sascha
  2. With my Nikon D800e in a Subal housing I use two wide angle lenses: a Tokina 10-17 fisheye and a Nikkor 18-35 mm.
    For ports I use a small dome, 100 mm dome, and an 18 mm extension. A larger dome might be a good idea, to get a smooth image with no corner cropping.
  3. 16-35mm for a number of reasons. Need a big dome 8-9"+ for rectilinear superwides.
  4. 16-35mm for a number of reasons. Need a big dome 8-9"+ for rectilinear superwides.
    ....I hear very often, that the 16-35 is in favor, why? How about the 12-24 or the 17-35?
  5. I'd have though either the Sigma 15mm or the Nikkor 16-35mm. Isn't the 12-24 a DX lens?
  6. I'd have though either the Sigma 15mm or the Nikkor 16-35mm. Isn't the 12-24 a DX lens?
    Sorry, you‘re absolutely right! I meant the 14-24 FX lens......
  7. Sorry, you‘re absolutely right! I meant the 14-24 FX lens......
    No worries. I read on WP some time ago that the 14-24 was very hard to house successfully and the 16-35 worked better. Worth a search for it.
  8. Hi,
    the Sigma 12 - 24mm is a FX lens since the first generation, as far as i know......
    A glas monster, but was the first ultra wide (weitwinkel) angle for film / FX.
    And is f4 now in the Art series.
    Regards,
    Wolfgang
  9. Sacha
    I found this on http://www.borutfurlan.com/articles/dxfx-en.htmlabout the use of the 16-35 and 14-24
    Dome port theory
    Dome ports are the most common correction system used in underwater wide-angle photography. The dome port is defined by two spherical surfaces (outer and inner) having an identical centre of curvature (centre of sphere) and therefore forming a concentric dome. The difference of curvature radiuses of both surfaces equals the dome port thickness, which must be completely uniform.
    The basic operating principle of a dome port is bringing the light rays into the lens in such a way that there is no refraction on the water-glass-air boundaries. This removes all CA, distortions and magnifications as the main optic problems occurring when the photos are taken from behind a flat port. This is only possible if the rays are entering the glass (almost) perpendicularly. Since all lines going through the centre of a sphere intersect the spherical surface at the right angle, the basic conditions for the successful correction with a dome port are placing the lens exactly in the centre of the sphere and perfectly aligning the lens' optical axis with the dome's optical axis. The light rays enter the glass approximately perpendicularly and therefore do not refract, retaining the lens angle of view.
    Consequentially, only zoom lenses that don't change its physical size significantly while zooming are suitable for photography with a dome port. Among the Nikon FX lenses, the 16-35mm f/4 is much more suitable than the "legendary" 14-24mm f/2.8, the latter changing the position of its front optical element strongly while zooming. articles_dx-fx_19.jpg
  10. Brilliant! Thanks a lot Tim!
    So the race is now only between 16-35 and 17-35....
    Best regards, Sascha
  11. ....I hear very often, that the 16-35 is in favor, why? How about the 12-24 or the 17-35?
    I read a good bit when deciding 16-35 vs 14-24. 17-35 wasn't a consideration (price, less wide).
    Many people struggled to get acceptable results in corners (challenge of rectilinear superwides) with the 14-24mm. Its much bigger, heavier, can't take filters, no VR and costs nearly twice the price. I believe some housing brands can't fit it too. It is a gorgeous lens though.
    There are times I wish I had 14mm (or 2.8) but there are MORE times I'm glad to have 35mm underwater. Sharks, dolphins, turtles, squid etc.
    Topside I've shot some lovely landscapes with a polarizer on the 16-35 (internet will say never use a pol on superwide, but works great in certain situations).
    Chris
  12. There is quite a lot of information on this forum about wide angle choices.
    A lens' performance on land is not a reliable indicator of how it will perform behind a dome port. The 14-24mm vs 16-35mm debate is a case in point. The 14-24mm is a superior lens, but does not works well behind a dome. Whether a lens is f/2.8 or f/4 (or f/5.6) has no relevance on FX as the shallow depth of field at these apertures means that sharp corners are impossible to achieve. I guess if all you are doing is shooting big animals in the blue, this is not a major consideration, but for everything else it does! Yes, you could crop the softness out, but this would also negate the advantages of a wide FOV!
    BTW the 17-35mm's corners are not great on land....
    Rectilinear wide angle with the D850 needs more examination though. For me, images produced by the 16-35mm with a 9" dome on the D810 was acceptable at apertures on around f/12 or so. I would expect the additional resolution to negatively impact on this, to the extent that the 16-35mm may no longer be a viable option.
    My feeling is that water contact lenses like the Nauticam WACP will probably be the best options for rectilinear wide angle with it.
    Adam
  13. One other thought...
    I have some experience with the Nikonos RS 20-35mm Seacam conversion. Initially, it had it's detractors who didn't feel it was that useful. 20mm was just not wide enough. (Stephen Frink seemed to do OK with it in the '90's:))
    There is some truth in that, but for the right subjects, I was very happy with the results. The small(ish) form factor and razor sharp corners were excellent. Also, unlike the 13mm RS conversion, the original lens is NOT selling for $3500+ USD. It is much more "affordable" than it's upscale cousin.
    Of course, this also assumes a Seacam housing. The zoom gear is integral with the lens, and despite numerous attempts, I was not able to make it work in a Nauticam housing, which the 13mm will.
    So, now I have a Seacam housing...
    I have now pared my UW lens collection down to the Nikonos RS 13mm, RS 20-35mm, Nikonos 15mm on Sony, and Nikon 105G for macro. The only thing I can't do is under/overs.
    I am completely satisfied with my setup. Now, if I were just a better photographer...
    ian
    Edited by ianmarsh
  14.
    I think this needs a rider the issue is movement of the entrance pupil while zooming whether or not it's a problem is going to depend to some extent what focal length range you are considering. For example the Olympus 12-40 does quite well at all focal lengths but it's only wide in the very bottom end of the zoom range (2x crop) and it gets shorter marginally from 12- 14 before getting longer and its entrance pupil doesn't seem to move a lot when zoomed. The 14-24 is very wide and even at the long end is still a bit wide.
    Regarding the need for better lenses for the D850, if you believe the premise behind the WACP wet lens, that the limiting factor is the dome port and a 28-70 kit zoom can do better than a superzoom behind a dome the natural conclusion is that the extra resolution is empty pixels and underwater a better lens can't deliver because of the dome interface. This may depend on how well optimised the dome is for the lens in question. which could be up to 10mm out from optimum placement if your chosen housing uses the principle of taking a standard dome and adding extension tubes with fixed sizes like 10, 20, 40 etc. so you are limited by what size extension tubes are available,
  15. I must say I am still a bit baffled as to why the high megapixels of the D850 is considered to be part of the problem when discussing soft corners.
    Does the various dome port theories not deal with the curvature of the dome, the way the light rays bends through the dome glass and how wide the lens being used behind the dome are?
    To the best of my knowledge, none of the theories state that the light will bend differently depending on the megapixels of the camera.
    Alternatively, if considering that the 14-24mm paired with the D850 delivers beautiful results topside, but not underwater surely we can agree that what has changed in the equation is not the megapixel count going from topside to underwater, but the fact that the 14-24mm is now behind a dome port.
  16. I disagree with the assertion (and the article excerpt above) that a moving entry pupil is the issue with wide-angle lenses and domes on FX. It may be the problem with some lenses, but others with a moving front optical elements work fine. It is down to how well an individual model of lens copes with the curved virtual image and the depth of field issues that this creates. The only way to know how a specific lens performs is to put it behind a dome port and test it underwater! Land tests etc. have no relevance to this.
    Ironically, choosing a fast (f/2.8 etc.) lens is also a complete red herring! Typically, large apertures give very small depths of field, which means that corners will be soft.
    Lens to port distance is crucial too and it will pay to spend time and gather information about the correct extension length. This is not as simple as it sounds either! Not specifically relevant to this discussion, but the optimal length of extension for the venerable Tokina 10-17mm with a few housings is actually 17mm. To my knowledge, no manufacturer supplies a 17mm extension.....So these are inevitably a compromise. In terms of the 16-35mm with Nauticam and 230mm dome, the correct extension seems to be between 60mm and 70mm, with most people opting for the latter. This (and all the other optical) compromise becomes more problematic as we increase the camera resolution....
    Geo is entirely correct in asserting that the physics of the light passing through the dome, entering the lens and being recorded on the sensor is not affected by pixel count. However, the extra resolution of the D800/810 (and now D850) dramatically show the optical flaws in the lens/dome interface. When we were using 20MP cameras, the level of detail that they recorded meant that, as long as the photographer was careful, the optical flaws in the system we used were not really noticeable. The increase in resolution means that the sensor records more detail and the D800/810 (along with the Canon 5DS/5DSr), really showed that the 16-35m/230 dome combination was not as good optically as we all thought. The D850 increases the level of detail in the images it produces by another 25% (roughly) so any flaws will also be 25% more visible. I have not shot the D850/16-35mm combination, so cannot speak from experience, but I have shot it a a lot with the D810 and am aware of its shortcomings at 36MP.
    What saves the day, as far as i am concerned are optical correctors that are designed specifically to deal with the water/air/lens interface. These optically correct the curvature of the virtual image, presenting an image to the sensor that is on a parallel plane. Nikonos lenses were examples of this and the 13mm is a great lens, although it is a fisheye so not really germane to this discussion. Ian has pointed out the advantages of the 20-35mm RS lens. For me though, they are not really wide enough.
    So we are left with the Nauticam WACP. The advantage of this lenses is that they correct the image so that the lens is able to produce an image that is optically the same as one produced in air. None of the standard lenses or cameras that we use are designed to deal with the issues of a curved virtual image. Land photographers (which is where most cameras get used) will never bump into this issue! While we were using 20MP cameras (or DX), we weren't able to see the flaws. The increased details available to us with high resolution FX cameras shows them up.
    Why is all this important? To be honest, if you are planning to share low res images online, it probably isn't. When we are underwater and shooting, there are so many things that we cannot control. Light varies, subjects are skittish (or absent), waves and surge make maintaining a stable camera platform a challenge, air supplies are finite and so on. One thing that we can control is our equipment choices. In order to give ourselves step best chance of obtaining the best image possible, we should not compromise. Choosing a camera like a D850 means that you are serious about image quality. To compromise this by using optics that are sub optimal seems (to me) to be a bad idea!
    Adam
    Edited by adamhanlon
  17. Personally I don't see what people say about higher resolution cameras showing 'flaws' to some point of damaging the image, though I keep reading it.
    I shot with 10-12mp cameras for many years, then jumped to a D800 (topside) and only saw vastly improved technical image quality, namely better resolution and dynamic range.
    I upgraded my UW housed D700 for a D810 a year and a half ago and again, only seen improvements. The resolution jump to the D850 is less significant and I personally doubt I'd see any worse performance from my 16-35 + 9" dome.
    2.8 lenses do have noticably superior autofocus as the AF sensor has a brighter image with which to work.
    Here's a shot D810, 9" dome, 16-35 @16mm, 1/200 f/8 ISO800. Overall image quality isn't perfect due to low light (30mins before sunset), but to me the corners are totally acceptable (corner crop brightened +1.5 stops for clarity here).
    Had another image from this series blown up about 2m across and looks fantastic. I don't think the D810's resolution makes the imperfect IQ worse at all.
    Chris
    Edited by Undertow
  18. Lovely image Chris,
    As always, is is hard to make any significant observations from images at screen res, and what is acceptable is very much a personal decision. Based on the crop of the right hand corner above, you can see how it is much softer than the center of the frame. So this is not an IQ issue, but a corner sharpness one!
    In my opinion, the beautiful lighting of the image combined with the fact that the corners are in shadow means that it is not too noticeable. The distortion is definitely there though. In a similar scene with different lighting it may well be more noticeable and hence detract from the image.
    For what it is worth, with the D810 and this scene, my inclination would have been to push the ISO up to 1600-2000 and close the aperture down to f/12 or so. The D810 deals pretty well with noise, and LR is very good at getting rid of it, yet corner sharpness is not something you can do anything about except crop it out.
    AF systems on newer cameras are very capable with slower lenses. Nikon used to use f/5.6 as the cut off for AF. At (lens) apertures larger than that, the phase detect sensors do not have sufficient angle of view so the AF sensor cannot "see" out to the edges. With the D810, Nikon modified the CAM3500TX AF sensor so that some focus positions can now be used with lens apertures between f/5.6 and f/8 and some at f/8.
    The belief that AF with faster lenses is better as there is more light falling on the AF sensor is (mostly) incorrect. It is to do with the angle that the light falls on the AF sensors. Hence, with the D810 and other newer cameras, there is no issue using slower lenses, beyond the ability of being able to open up the aperture to get sufficient light to expose the image correctly. Given that with rectilinear lenses on FX using a lens at larger apertures does not produce sufficient DOF, it is a non issue for rectilinear wide angle lenses that we use underwater.
    Adam
  19. Thanks for your thoughts Adam.
    I was actually referring to both the dome corner sharpness issue and overall imperfect IQ there. To me the dome related corner blur in that image isn't bad at all and wouldn't be distracting even if not in the shadows. If not obvious at screen res, the blur is really only in the lower right quarter of the crop. The left side is at normal image sharpness (which isn't perfect in that image!).
    Out of curiosity I found another image last night, again low light pre-sunset, where I accidentally shot some images at f/6.3 of turtles over sand/seagrass. The bottom corners were closer to the camera and they're total freaking mush. So it depends.
    It is all about personal preference. I find the corners in that image very acceptable so in retrospect I would not have pushed the ISO as it would sacrifice dynamic range, upon which that image is very reliant. I absolutely agree about noise though.
    You're right that AF variations for wide lenses underwater are generally insignificant. I have seen a difference but am also totally happy with my f/4 lens there. It is the only lens I own slower than 2.8 and I occasionally bemoan that, but usually just topside.
    Chris
    Edited by Undertow
  20.
    BTW the 17-35mm's corners are not great on lamd
    Adam
    Are you sure? Not in my experience. I use 17-35 massively in land, which is a lens that need to be closed by f/8 f/11, anyway I've made a lot of wide aperure shots and the pictures are good, very good. I tried the 16-35 without recognise particular sharpness improvement, inspite of that the AF performane is better and the VR function can help in partiular occasions, but is a less fast lens (f/4) and a little bit bigger. Of course, Nikon users like me are waiting for a modern version of the old 17-35/2.8, but Nikon at that time appears interested to others strange things (180-400/4 Tc a Rolls Roice tele zoom, good luck Nikon)
    In water using D800/D800E behind Sea&Sea 240 achrylic dome port, I've reached good very good sharpness from corner to center with the cheaper 18-35 Afs closed to f/11 - f/13 adding the correction lens sea&sea CL77 and a couple of extension ring 20+40. But still there is a great lack in the minimun focus distance: 27cm are still too much.
    I plan to purchase a nikon 20/1.8 afs and, probably, the newest Sea&Sea 230 glass dome; finally, I hope, I'll have the anphibic rectilinear wide angle camera that I'm looking for.
    Edited by vbpress
