Seafrogs ST-100 Pro Underwater strobe - need your openion
Started by Ahmed Yahya ·
  • 43Posts
  • 43Replies
  1. You're right, I'm not sure what it was, but one of my strobes was always firing in TTL, regardless of anything, while the other was sometimes doing a single flash instead of double, resulting in a lopsided exposure, and the right magnetic switch sometimes had an effect on it, and sometimes not - and it seemed different between on land and at depth, and sometimes turning it off and back on fixed it.
    For what it's worth, I was able to figure out this issue, eventually. The fiber optic sockets in my housing are offset to the left from the flash head, and there is a little reflector guiding the light to the left socket, which ends up not aligned with the flash (the right one is fine). The resulting weakened pulse is sufficient to trigger the attached strobe on the stronger main flash, but not on the weaker pre-flash. Fortunately, the fiber optic cables that shipped with the strobes had a double FO plug in each box - I disassembled the Sea & Sea type L-shaped plugs on the cables, put the cables into that plug, and now both cables go into the properly aligned socket.
  2. I sent an email to SeaFrogs discussing my strobe flashing and not firing. They replied that I would need to send strobe to their office for inspection and repair and provided an address to send to. I wrapped strobe in bubble wrap, built a small box from an old camera lens box, and packaged as small as possible and mailed First Class International (no insurance or other options). The cost to mail this way was $24 which is less than what I had seen on various sites like this one but others may have included more mailing options or larger boxes. I will let you know what they decide after they inspect the strobe and respond.
  3. I mailed my strobe to SeaFrogs on June 17.  Postal tracking indicates it was delivered to their Hong Cong address the morning of June 25.  After not hearing anything from SeaFrogs for a month I sent them an email on July 25 requesting status of their inspection and repair.  On July 27 I sent a followup email with the postal tracking info attached and asking when I could expect their evaluation of the strobe.  After a week, they have not responded to either email.  Definitely disappointed with SeaFrogs lack of customer service and lack of even responding to my emails on status.  At the least they could let me know if they if they plan on doing nothing so that I could make plans on obtaining another strobe.
