Atomos Shinobi
Started by Lionfi2s ·
  • 41Posts
  • 41Replies
Atomos Shinobi
  1. you would hope the inbound ninjaV housing would fit this also - my only concern is the different battery mounting.
  2. good price point but is touch screen?
  3. good price point but is touch screen?
    Unfortunately, just watched a review. So unless Nauticam or someone else finds a good way around it... no good for UW use
  4. They did indeed come up with a good solution I am at ADEX singapore here is the pic of the housing for ite5c91ffadc42b577bc5ae4e54fffe933.jpg
    Sent from my SM-N960F using Tapatalk
  5. I see no benefit using this and other recorders with HDMI 1.4 however it does make a good monitor though I am sure this will be over $1600
  6. They did not mention the price however one of my friend sent me a screenshot of the price listed on their website for awhile and they took it out it is not that much more expensive than 502 housing
  7. I see no benefit using this and other recorders with HDMI 1.4 however it does make a good monitor though I am sure this will be over $1600
    Depends on the camera you use but anyway Shinobi is just a monitor not a recorder.
  8. Depends on the camera you use but anyway Shinobi is just a monitor not a recorder.
    $1800+400=$2200 for a monitor slightly less expensive than smallhd bright but still fairly expensive for a monitor wouldn’t you agree?
  9. $1800+400=$2200 for a monitor slightly less expensive than smallhd bright but still fairly expensive for a monitor wouldn’t you agree?
    Totally but no cheap options out there. We are a niche market and manufacturers take advantage of that. The monitor price is ok the housing price is ...
  10. How much would you pay for a 5.5” underwater monitor?
  11. I found the price already it is $1600 which is exactly the same as 502 housing this is quite interesting as the atomos is also cheaper than smallhd502 monitor
  12. I found the price already it is $1600 which is exactly the same as 502 housing this is quite interesting as the atomos is also cheaper than smallhd502 monitor
    Total $2000 then?
  13.
    Total $2000 then?
    Umm I am looking at the shinobi monitor and just realized that their battery layout is in different spot dont know if this will work if i remember correctly the housing is not a total square they have the battery part cutout so it fit the battery. Also i asked them about fitting in a normal size ssd inside and they said it wouldn't fit so if anyone is planning to use this they need the atom x ssd.
  14. Sorry I thought shinobi and ninja v is the exact same design just without recording function but seem like they are not so identical.
  15. Sorry I thought shinobi and ninja v is the exact same design just without recording function but seem like they are not so identical.
    Ok so this housing is for ninja V as it has a record button
    So 1600+599=2199 for a monitor recorder?
    And nothing for the shinobi as such yet
  16. Ok so this housing is for ninja V as it has a record button
    Yes that is correct 2199 missing battery and storage and nauticam hdmi 2.0 cable they stated it on their website as sold separately.
  17. Yes that is correct 2199 missing battery and storage and nauticam hdmi 2.0 cable they stated it on their website as sold separately.
    Considering the HDMI 1.4 nauticam limitation this is an alternative to an inferno or flame
    695+1600+disk etc
    But maybe you can just have it as a monitor still less than smallhd
    Anyway not for me I am happy with avci in the memory card
  18. The Inferno (NA-FLAME) is also getting the M24 port too.
    Will post up about the new GH5V and revised Inferno housings shortly....
