For Sale: Saga TRIO, Nauticam Wet mate port, CMC-2, Arms, YS-D2, Nitescuba lights and canister light
Started by andreysavin ·
  • 21Posts
  • 21Replies
  1. US$ 495
    My name is Andrey Savin. I live in the Philippines (Negros Oriental, near Dumaguete)
    I can ship worldwide. Buyers pays shipping cost and bank/PP fee
    Payment via PayPal or Bank transfer
    The package is presented in the photo. The condition is good, never flooded, never repaired, the lenses are clearly fixed in the desired position. The thread works fine, does not stick. No scratches on the glasses. On the body there are a couple of scratches - they can be seen in the photo. Bought 2 years ago in Hong Kong.
    Shipping cost https://www.phlpost.gov.ph/get_rates.php(1 US$ = 51 PHP, parcel gross weight not more 1 kg)
    My other lots for sale here : Nauticam CMC-2, Nauticam Wet Mate lens, Retra LSD snoot, 7x arm set, pair of Nitescuba S1 video lights, pair of Scubalamp V6K video lights, pair of Orcatorch canister torch D620, ...
    SAGA Trio specifications:
    • Size: 136 x 84 x 73mm
    • Weight: 708 gr/1.6 lbs
    • Weight in Water: 200 gr/.44 pounds
    • Aluminum 6082
    • Hard anodized, with extra hard on the working areas (Thread and levers)
    • Lenses are Vacuum Sealed
    This lens revolutionizes all the wet magnification systems now available. You can switch between 0, +5, +10, +15 diopters quickly all with one device! The patented system of two levers makes it possible for photographers to use a very easy system of changing the magnification, even while they are looking through the viewfinder. Trio allows you to reach 4 different power ratios in the minimum time possible, and with maximum optical quality.
    Manufactured in mechanized aluminum with hard anodizing, Trio has two groups of lenses, one with a +5 diopter and the other with a +10. These two groups can be moved independently, so 4 levels of magnification can be achieved. With the the two levers in the upper position, you can use your lens normally - focusing to infinity as normal without any vignetting.
    The Trio lens system is designed to be used with macro lenses such as the Canon 100mm or Nikon 105mm, even with some 150 or 180mm lenses, and it can also be used with 60mm macro lenses.
    Flipping the first lever adds a +5 diopter, second one adds a +10, and with the 2 levers in the lower position stacks the two groups of lenses and for a +15 diopter lens.
    The lens is attached to any 67mm threaded port. If your port doesn't have a 67mm thread, Saga Dive makes an adapter for any kind of port.
    Once it is attached, the lens can be moved to any place by rotating, so it can be rotated to any preferred position we prefer, for flexibility with lighting.
    Edited by andreysavin
  2. US$ 125
    The package is presented in the photo. The condition is good. Only 2mm scratch on front lens. Absolutely not visible in the photos
    Shipping cost https://www.phlpost....h/get_rates.php(1 US$ = 51 PHP, parcel gross weight not more 1 kg)
    My other lots for sale here : Nauticam CMC-2, Saga Trio lens, Retra LSD snoot, 7x arm set, pair of Nitescuba S1 video lights, pair of Scubalamp V6K video lights, pair of Orcatorch canister torch D620, ...
    My web site www.uwart.pro my instagram @uw.art
    This is the Nauticam 67mm wet mate dome for compact camera housings. This ultra-compact dome restores the original angle of view of your lens, resulting in a 30% wider angle of view underwater. This dome works well with all compact housings with 67mm threaded ports, such as the Nauticam S100, S110, LX5, LX7 and RX-100 housings.
  3. US$ 200
    My name is Andrey Savin, living near Dumaguete City, Negros Oriental, Philippines.
    All contact info on my web site www.uwart.pro
    Shipping : worldwide by PhilPost / DHL / LBC.
    NB : Buyers pays shipping cost and bank/PP fee
    Payment : PayPal or Bank transfer
    The package is presented in the photo. The condition is very good, the lens surface are clear, no one scratch
    Shipping cost https://www.phlpost....h/get_rates.php(1 US$ = 51 PHP)
    My other lots for sale here : Saga Trio lens, Nauticam Wet Mate lens, Retra LSD snoot, 7x arm set, pair of Nitescuba S1 video lights, pair of Scubalamp V6K video lights, pair of Orcatorch canister torch D620, ...
    This lens, which is designed for compact and mirrorless camera users, doesn’t replace the company’s CMC-1, but rather complements it, offering less extreme 2.8x magnification (compared to the CMC-1’s 4.5x). Nauticam claims that there is an increase in the sharpness and contrast of shots taken with CMC-2 by comparison with those taken behind a flat port.
    Constructed using specially formulated low-dispersion optical grade glass with broadband anti-reflective coatings, the CMC-2 has a protruding rear element, which places the lens close to the camera port when used with flip lens adapters. It can also be mounted directly to an underwater housing using the included flush mount adapter ring.
  4. US$ 99 for all
    4x arms | full lengs 200 mm, effective lengs 180 mm
    2x arms | full lengs 130 mm, effective lengs 110 mm
    1x arm INON Multi ball arm LL
    2x 1-inch ball adapter 38,5 mm x 25,4 mm
    2x connectors
    total 11 items
    I prefer to sell at once, but will consider offers for sale in parts
    International shipping cost https://www.phlpost....h/get_rates.php(1 US$ = 51 PHP)
    My other lots for sale here : (will post soon) ... Nauticam CMC-2, Nauticam Wet Mate lens, Saga Trio lens, Sea & Sea YS-D2, Retra LSD for YS-D2, 6 arms, 2х Nitescuba S1 video lights, 2х Scubalamp V6K video lights ...
    Inon multi ball spec: (Product Code: 1141351000000)
    ■Full length: 401mm (15.8in)
    ■Effective length: 380mm (15.0in)
    ■Weight: 123g (4.3oz) [air] / approx.75g (2.6oz) [underwater]
    ■Compatible options:
    M5 Joint + Shoe Base Spacer
    M5 Joint + Lens Holder for Float Arm
    M6 Joint + Direct Base III
    M6 Joint + Direct Base YS RT
    Stick Arm Float S (maximum two)
  5. US$ 299
    Kit: strobe, L-type optic cord, diffuser 100, diffuser 120, spare o-ring, ball mount adapter, YS-adapter, щ-ring grease, original box, papers
    The flash works correctly in all modes, not poured, not dropped, tested by me personally at a depth of 30 meters.
    Disadvantages: there is no black cover closing the hole for the optical cable, scratches on the ball mount adapter - everything is in the photo
    My other lots for sale here : (will post soon) ... Nauticam CMC-2, Nauticam Wet Mate lens, Saga Trio lens, Orcatorch new Canister torch, Retra LSD for YS-D2, 6 arms, 2х Nitescuba S1 video lights, 2х Scubalamp V6K video lights ...
    The new Sea & Sea YS-D2 flash replaces the already highly popular YS-D1 model with a number of improvements:
    • Faster recharging - With lithium battery, flash is ready again_in 1.4 seconds
    • Redesigned buttons - You will no longer accidentally get turned on one of the buttons
    • Target light with two options (100/300 lumen) and red filter
    • The rear panel is with backlit lights, so you can see the buttons in the dark
    • Audible sound when the flash is ready again
    • Redesigned casing, which protects the rest of the flash in the event of a leak
  6. US$ 199
    My name is Andrey Savin, based near Dumaguete City, Negros Oriental, Philippines.
    For sale my Retra LSD Ultimate Light Shaping Device in good working condition, only some scratch...
    Kit: Retra LSD, 3х mask, Case
    My other lots for sale here : (will post soon) ... Nauticam CMC-2, Nauticam Wet Mate lens, Saga Trio lens, Orcatorch new Canister torch, 7x arm set, 2х Nitescuba S1 video lights, 2х Scubalamp V6K video lights ...
  7. US$ 199
    For sale pair or my favorite video light. I have two. Price for one
    Kit: Torch with original battery, carry case, strap, charger and both (YS / 1-inch ball) mounts
    Spec is here
    My other lots for sale here : (will post soon) ... Nauticam CMC-2, Nauticam Wet Mate lens, Saga Trio lens, Retra LSD snoot, Orcatorch new Canister torch, 7x arm set, 2х Scubalamp V6K video lights ...
  8. US$ 199
    For sale pair or my canister dive light. I have two. Price for one
    It was bought for me and my buddy for dive trip to Mexica, but we have change our plans - so thats why i am selling this items in new condition
    Spec is here
    My other lots for sale here : (will post soon) ... Nauticam CMC-2, Nauticam Wet Mate lens, Saga Trio lens, Retra LSD snoot, 7x arm set, 2х Scubalamp V6K video lights ...
    Alloy Aluminum Reflector with Professional Optical Analysis The light provides a 78° wide beam with a penetrating center 14° beam angle from its alloy aluminum reflector with professional optical analysis design. The light beam distance is 853' (260 meters) on land and max intensity 16870 cd.
  9. What mount?
    (In relation to the Retra LSD above: Admin)
    Edited by adamhanlon
  10. Mount for Sea and Sea YS-D2 or YS-D1
  11. Do those spots create any noticeable artifacts in the lighting? Also, I am curious why you are selling all this setup, You have what looks like a pretty formidable setup you are letting go.
  12. Absolutely no spots Retra snoot does not create - only a uniform light spot. I have a lot of underwater photo and video equipment, some of which I decided to sell.
  13. CMC-2 SOLD
  14. Offer free shipping all Philippines
  15. price for Retra?
  16. CMC-2 and YS-D2 SOLD
  17. On 7/30/2019 at 4:12 AM, nickga69 said:
    price for Retra?
    $200 + shipping
  18. RETRA SOLD
  19. On 7/14/2019 at 2:53 PM, andreysavin said:
    US$ 495
    • Aluminum 6082
    Is the SAGA Trio still available?
  20. That's a great deal on the OrcaTorch lights.  Good luck with sale.
