22 hours ago, jjmochi said:Thanks everyone for your advice. I did end up buying the 45 degree viewfinder and taking it with me for 3 days of diving at Anilao. It was a bit hard in the beginning but I got used to it after the first day. I will do a proper trip report later but I'm quite pleased with the results, definitely a lot to learn still but I could see a real improvement over what I was doing before with a PnS. Have not gotten to learning editting yet so I just put everything through the dive+ app.
I have a few more questions based on the last trip:
1) I weighted my camera without the float arms in fresh water (bathtub) before the trip and it came out to be 1100g negative. I bought 2 float arms for +450g each, so I should have been -200g negative in freshwater. However in saltwater it was too positive!! Tried it for the first two dives and it kept floating up and was really hard to handle, I also had to add 1kg of weight myself just to descend. I ended up just diving without the float arms for the rest of the trip which was tiring but at least I could stay still. But for the next trip I would like to get the camera weighting right, but don't want to buy new float arms - is there any way to weigh down the camera? I was thinking I'll add my go pro on top but not sure it'll be enough.
2) My legs kept floating up - it was so hard to stay still and impossible to swim backwards. I am using Atomic Splitfins, which I really liked before as I could move through current really easily with minimal effort. The dive shop recommended I get Jetfins instead as they are much heavier. I am wondering if Splitfins are really just not suited for photography and I should buy a second pair of jetfins, or if it's a issue of skill / buoyancy control?
3) My air consumption also went up a lot with the new camera. I ended most dives at 60 min and 50 bar. I used to come up with slightly more air than my husband when I was using the TG5, but this trip he came up with ~90 bar and I am at 50. The only thing that changed was the new camera but I am shocked at how large of a difference it made - curious if others experienced this also and if this will get better over time?
4) I kept bumping my mask against the viewfinder and sometimes it would cause a leak which was annoying - should I be looking through with some distance, or is it correct to have the mask pressed against the viewfinder like you would do on land?
5) Strobes - previously I was using Inon S2000s on TTL, and batteries lasted the full day / 4 dives. I switched to the Inon Z330s on manual this trip and dove the first day on max setting and the batteries ran out during the second dive! Switched to half setting next day and it lasted 3 dives but still ran out on the 4th dive. Is this normal? I'm just surprised there is such a big difference.
I was shooting with the 85mm lens on all dives and think I'll try the 60mm lens next time - some things like the giant frogfish, turtles, and stingrays were definitely too large to shoot with the 85mm - I had to be so far away that my strobes (Z330s) couldn't even light it at the highest setting and the water was not clear at all (maybe 5m visibility) so everything came out murky and blurry.
Also the dive master told me I moved way too fast - that most photographers only shoot 3 to max 5 subjects per dive. Curious if that's the case? How long do you typically spend on a subject?
Getting float arms right can be an issue, 1100 gr negative sounds like a lot, it can be tricky making sure the camera is really floating and 100% submerged, you don't change 200gr in buoyancy between fresh and salt water. You could certainly come up with some way to add some lead to your rig to get it weighted right, it does not take much positive buoyancy to be really annoying. You could try to find some way to attach some fishing sinkers or for a neater soulution try something like this: https://www.amazon.com/Canon-WWDC1-Weight-Waterproof-Weather/dp/B0002DF0FU which could add up to 240gr to your housing.
If you legs float you might consider ankle weights I know my daughter had lots of problems with floating legs which can be a real issue for females. Probably only need 1lb weights. There seem to be some weighting nazis around who insist that you can achieve it some other way but for some people it's the only real solution. Having said that jet fins are 2 lb heavier - I would suggest seeing if you can try a pair to see if you like them.
What batteries are you using in your strobes? the TG-5 shooting wide is f2 or f2.8 so needs a lot less power than shooting at f11-16 for macro on a DSLR so it makes sense you should get less life out of them . I have Z-240s and with eneloop pros can get at least 3 dives in shooting at f8. I'm surprised you needed max setting though for macro when you are close to your subject. Going from 100 to 200 ISO for example halves the required light so should theoretically double the number of shots. Same with moving aperture 1 stop.
Air consumption has as much to do with how relaxed you are as the physical effort - you may find yourself getting better with time.
Shoot as many or as few subjects as you like on a dive - that's up to you. Personally I'm not a huge fan of getting 100 near identical shots of the same subject that I need to sort through and edit. I'll take a some frames until I'm happy and move on.
Regarding your frogfish, even the 60mm would be challenging I would think, I'd be tempted to do a dive with a medium wide lens to shoot them in the conditions you describe.
