Adapters for Subal Housings
Started by Neptune63 ·
  1. Hi,
    Does anyone know if someone makes adapters for Nautical ports so they fit onto Subl Type 3 housings?
    Thanks!
  2. Most likely not, as Nauticam's port mounts are much bigger in diameter than even Subal's type 4 mount. For most port adaptors to work, it typically needs to be the other way around with the port's mount being the smaller to the housing you're hoping to mate it to.
  3. I regularly use Nauticam ports (including the WACP) on my Subal housings (type 4 ports) - I use an adaptor from Saga.
    I am pretty sure that the difference in port to lens difference is 30mm longer like this (Subal housing sticking out more and the adaptor - compared to the original Nauticam port on a Nauticam housing).
  4. On 8/15/2019 at 2:49 AM, ChrisRoss said:
    Google is your friend:
    Not if you are a Trump supporter
    Edited by John Doe II — removed "Lets go Brandon"
