Did anyone already 3D-print a Nauticam DSLR Zoom Gear?
Started by Michael T. ·
  1. ...and is willing to share the *.stl or other CAD-file (IGES, STEP)? I want to test print one but found only files for 4/3 housings and they seem to be too small. Looking for a file for DSLR.
    TIA
    Michael
  2. This is a gear for a Nikon 70-180 zoom in a Nauticam housing. My CAD program can out put in many different formats. I sent a .stl off to have this one printed. It works well in my housing, but could use a few  tweaks.
    Charlie
    View archived post in: 3D Printed Parts
  3. hi there,
    I thought i would bump this thread, i am after a Zoom gear for the Nikon 10-24mm lens, into a Nauticam housing.
    I will very scarcely use this lens, so would like to avoid buying the full blown regular gear that Nauti sells...
    Else if i could borrow from someone in Australia... :)
  4. If you have any other gears, it is sometimes easier to make a gear adapter. When I bought my housing (used) it came with a gear for the Olympus 12-40 lens. I kept the outside metal ring and then printed a different inside plastic part. I got close enough in my first try that I only need to slide a small piece of paper between camera and gear for it to work flawlessly.
    I'm a music teacher, not an engineer, so I think if I can do that, everyone can.
