Strobes VS Video Lights - Can underwater video lights be used for underwater photography?
Started by Tom_.park ·
  1. Strobes VS Video Lights - Can underwater video lights be used for underwater photography? A few years ago I was a strong believer that video lights were just not powerful enough, but my opinion on this has totally shifted - Video on the matter:
    https://www.youtube.com/watch?v=RjmYtUQCFOw
  2. @Tom_park Here you go:
    Edited by adamhanlon
  3. I really would like to see some comparisons on similar compositions made one with strobe second with flash. I have very old two flash lights and thinking about upgrade. My video lights 4000 lumen each are to poor to photography.
    Is it possible to use lets say
    - at clean coral reefs
    - 2 x 10000 lumen lights
    - iso 200-800
    - aperture 2.8-5.6
    and get colors and sharp image in few meters distance at 25 deep meters where blue is dominating with APSC or Full Frame camera?
    Edited by PiotrPL
    - iso 200-800
    - aperture 2.8-5.6
    See here:
    View archived post in: Tested: Strobe vs 14k lumen Video Light; Sea & Sea YS-D2 vs. Gates GT14
    - iso 200-800
    - aperture 2.8-5.6
    You might get close with good exposure/colour particularly at the higher ISO, but the other parameters will be a challenge.  f2.8 is very fast for UW and there's really no wide angle solution which will not have mushy corners there.  you might get f5.6 with a WWL/WACP type water contact optics.   A fisheye you would probably want f8-11 and a rectilinear wide f11-16.  The other issue is pointing such bright lights at a subject often causes it to leave, which may not be a problem with video but could present challenges getting into position for a good composition for stills.   I would also expect you would want to be closer than a "few"metres - probably more like 1m.
    - iso 200-800
    - aperture 2.8-5.6
    View archived post in: Using Video Lights for Still Photography?
    Old topic but may help.
  7. Thanks a lot for links to other post ... they helped a lot to answer few my questions
    Happy it was useful.
    Diggy
