S-Turtle Mobie - Sony A6400
Started by ScottAudette ·
  • 26Posts
  • 26Replies
  1. Hey hey,
    Figured it might be time to break this out from the monster thread Turtle thread. So, thanks to @TimG and some windex I can now get the S-Turtle to trigger. YES!!!
    But now on to my next dilemma. I am trying to get the trigger to fire during a motor drive sequence. @Phil Rudin I know you've mentioned getting this to work. It works perfectly for me with electrical sync via the bulkhead. Makes photographing the sharks so much easier.
    I've tried WL Manual mode with first curtain sync. All i get is ONE frame. Very bright LED trigger then nothing. In my mind manual mode should be the same as electrical sync.
    thoughts?
  2. So are the trigger LEDs firing every time or not?  If the trigger LED fires just once it could be a trigger problem or the camera may not think the flash is ready perhaps?
    I had the same thought: the camera may not think the flash is ready.
  4. The LED only fires on the first frame of the sequence.
    Actually, I think it's the trigger not returning to ready state. I am using the camera in WL mode for manual strobe firing. So, no TTL. It should just be sending a sync to the trigger no other communications.
    If you wait a split second and don't motor drive it works fine. I'm working with @Balage_diver in this as well. His trying to get his hands on a A6400 this week and test on his end.
    yes certainly sounds like a camera specific issue.  Does the A6400 have a manual flash mode?
    It could be camera-specific or it could be trigger-specific.
    With my Sony (a7rIV) and UWT trigger, I can run the camera in Continuous Drive (I KNOW I've tested it up to at least Mid speed) and the trigger will fire every time (5 fps or so).
    Scott, do you have a regular camera flash unit (for land use) that you can plug into the hotshoe to see if it will fire repetitively in Continuous Drive? That could help you identify whether it's the camera or the trigger.
  7. So, here's the breakdown from testing:
    Electrical Sync via bulkhead:
    Works as expected fires everytime
    Canon 600 land strobe:
    Also fires as expected. Everytime in sequence.
    Now once I switch to manual using the WL mode on the camera I get one frame. And I can't test it with a land strobe because it doesn't see it. @Balage_diver said it works with his Sony A7III, (could be different one but I forget LOL)
    Hopefully he's able to get an A6000X series camera to test with!
  8. Scott, I have an A6100 and Sturtle. i will see if I can recreate your scenario and how mine performs.
  9. @Balage_diver has been working with me on this for a bit now. He's found the same things happening as I did. So here ia a little bit of a wrap up!
    The A6000x series will not work in mid continuous or high continuous with the Sony Turtle. Neither in TTL or WL/Manual. He had hoped it would be an easy fix but it's not.  So there is no timetable on this.
    Also when using the Turtle in TTL the first frame would be exposed perfectly. Consequently if you fired the camera again quickly the next few frames were typically blown out. Like nuclear. He's ordered a YS-D3 to look further into all this.
    So, we at least know the Turtle with 150 leds WILL fire a Sea & Seas YS-D3 Lightning.  Just that there are a few other issues.
    Now, I bought this to use in my pool studio to fire FO manually. It does that so I am going to keep it just for that. And will stick to my electronic bulkhead for diving. That fires every time and can even cheat up up the Sony's flash sync to 1/200th.
    Does it work in Continuous Lo?
    When you mention the bolded part, are you talking about shooting in Continuous Lo? Or Single frame and hitting the shutter release rapidly? If so, how rapidly?
    Just an FYI, once I adjusted the LEDs properly on my UWT trigger, it would fire the YS-D3s reliably (with 613 f/o cable). At least, in my house. I didn't get to try it in the water. Also, I don't know about the a6x00, but with my a7rIV, the UWT gives me 1/250 sync speed - with fiber optic.
    Yes, single frame. Let's say half a second and I fire that in TTL. That frame would be overexposed.
    The A6400 max sync is 1/160th. With electrical I can eek it 1/200th. With FO it's 1/160th, anything above and you get clipping.
  12. And I've now had no issues with it firing reliably now in single mode. It's just not reliable in TTL with this camera or in any drive mode beside single.
    I seem to recall some Sony models has 1/160 sync by default and would allow a higher speed if a Sony external flash was installed and some trigger setups take advantage of that.
    That is unfortunate. :(
    I tried mine with the UWT trigger in TTL mode in the water about a month ago. I shot it in Continuous Lo and Continuous Mid and the TTL seemed to work just fine for me. But that was on an a7rIV with Inon Z240 strobes. I think it's going to be pretty useful in some situations for me.
    With my A6300 and UWT trigger, setting it to speeds higher than 1/160 puts the trigger in HSS mode.
    By the way, I just tested my setup - A6300 with 90mm f/2.8 G, UWT trigger, Retra Pro with supercharger, manual mode, 1/160s, f/2.8, ISO 100, camera set to WL flash, Retra set to manual mode ('ON') and 3% power (2 clicks up from minimum) and it had no problems producing full exposures in both Hi and Hi+ drive modes.
    Thanks! Maybe I'll return the the Turtle and try the UWT.
    That's probably a bit of an overkill; I'm reasonably sure TRT can fix the problem with a firmware update. I know for a fact that Alex Tyrell (http://dive4photos.com/) uses a Turtle trigger with a Nikon D500 on continuous drive without issues, so the issue is specific to the Sony model. Retra Pros with superchargers at quarter power can do 3-4fps basically until the camera buffer fills up. Also, keep in mind that the UWT triggers are not field programmable - if you get one and it needs an update (for instance, to add a new strobe model), you need to send it back to Pavel in Moscow.
  18.
    I guess it just depends on how long he wants to wait.
    That is awesome that the RPs can do 1/4 power at 3-4fps. Any chance you could test them at 6fps and see what power level you can use? Even for just a 1 - 2 second burst?
    I'm asking about 6fps because my camera is "up to" 3fps on Lo and "up to" 6fps on Mid. I would love to learn if the RP w/Supercharger can handle 6fps and at what power level. I'd guess a full 2 second burst is probably the most I would ever shoot it for without pausing at least for a short time.
    Based on the conversations I had with Balazs it's not going to be any time soon. Said it was going to be a massive undertaking with no timetable for it.
