Do you prefer a 45 or 180 degree viewfinder?
Started by rayanthony ·
  • 27Posts
  • 27Replies
  1. 2 hours ago, diggy said:
    Maybe the 45 takes some time to get used to ?
    Yeah, it does, Diggy. Especially when sort-of panning to frame wide-angle or mid-water shots. But you do get used to it. I've had mine coming up on 15 years so am getting the hang of it....:rolleyes: I'd never leave home without it now.
    You won't believe how embarrassing it was for me when I had arranged an underwater lesson on a dive for a relative newbie. He had a Sony system if I recollect correctly with a 45 degree viewfinder. Guess what ? I could just not find the proper frame or subject looking through it and had to abandon the lesson :angry: So much for experience and teaching !
    Will definitely give it a try again. Thanks Tim.
    Diggy
  3. I am a 45˚ person. Persuaded to get my first by the Wetpixel forums. I know have 4 - which is a bit excessive!
    Brilliant!!!
    Thanks Alex,
    Some very valid and pertinent points made. Sadly now I will may be looking to buy a 45 degree viewfinder. But before that will borrow one for a trip and see where I am at. Last I tried using one was a COMPLETE disaster.
    Diggy
  6. I prefer the 45 degree viewfinder and used it for over a decade. I can comfortably look down to compose and don't have to hyper extend the neck whether shooting macro or wide.
  7. I now have both and can try them out back-to-back starting next week.   I've shot the 180 since 2016 on a D810 then D850 Nauticam housing.
    I was able to try a 45 degree finder at the Digital Shootout in Bonaire in June.  In July I bought a Z9 and housing for it, and I was told you had to change from a DSLR viewfinder to a ML viewfinder, so the 180 I had would not ... work?
    I bought the 45 degree ML, and I'm sure I'll like it for macro.   But for wide angle, I'm not so sure.  There are a lot of times I take a landscape shot and immediately rotate the camera vertically and get a portrait shot of the same subject.   With the 180, this is trivial.
    Anyway, I was curious to see if the 180 would fit the Z9 housing, so I tried it.  Fits just fine!  So I looked closely at the housings just now - the viewfinder mounts are identical!
    Maybe the ML viewfinders somehow make the eye-detect monitor/viewfinder swap work, but I don't think so.
    At any rate, I have both viewfinders and will find out soon if there are any deficiencies in the DSLR 180 on the ML camera.
