Not totally surprising though. Panasonic has been pretty stubborn on this, as they are convinced their method is technically superior (which it is, but unfortunately not with the amount of processing in their cameras). Maybe it will actually be good in the GH6. I won't shoot it down before people have thoroughly tested, but it probably won't be Sony levels of AF.
Panasonic GH6: from rumors to reality
Started by Davide DB ·
- 24Posts
- 24Replies
Huge leak from https://digicame-info.com/2022/02/gh6-10.html
Camera dimension is huge. It seems a S1H. Even a fan!
- 4K120p 4: 2: 0 10 bit 300 Mbps
- 4K 60p 4: 2: 2 10 bit 800 Mbps /
- 600 Mbps 5,7 K 60p 4: 2: 0 10
- bit 300 Mbps C4K 120p 4: 2: 0 10 bit 300 Mbps
- C4K 60p 4: 2: 2 10 bit 800 Mbps / 600 Mbps Apple ProRes and MP4, MOV 5.7K 30p Apple ProRes 422 HQ 1.9 Gbps
- 25 million pixel PLF-less sensor
- High resolution shooting of 100 million pixels
- 5.7K video
- Sensor readout up to 300fps
- High-speed readout of 120 fps at 4K resolution
- Rolling shutter suppression
- Computational processing capacity is about double
- New intelligent details New 2D noise reduction High-performance 3D-NR (video) Improved AF performance Processing speed is 3 times faster than before DFD performance has evolved
- New recording mode 4K120p 4: 2: 0 10bit 300Mbps 4K 60p 4: 2: 2 10bit 800Mbps / 600Mbps 5.7K 60p 4: 2: 0 10bit 300Mbps C4K 120p 4: 2: 0 10bit 300Mbps C4K 60p 4: 2: 2 10bit 800Mbps / 600Mbps Recording file method supports Apple ProRes in addition to MP4 and MOV 5.7K 30p Apple ProRes 422 HQ 1.9Gbps
- Card slot: CFexpress TypeB slot, UHSII compatible SD card slot Weight: 739g
- Dynamic range boost function: It is possible to shoot a wide dynamic range image at a maximum of 60 fps by synthesizing an overexposed image and an underexposed image in real time. Achieves a dynamic range of up to 13+ stops approaching the full size. The minimum ISO sensitivity is 800, and when using V-log it is 2000, so an ND filter is essential. Image stabilization: Adopts an ultra-high performance gyro sensor and a new algorithm, and has a correction effect equivalent to 7.5 steps. Smooth image stabilization that is ideal for movies. Dark place performance: High-sensitivity noise is much suppressed compared to GH5II while increasing the number of pixels. It can be used normally up to ISO3200. Built-in microphone evolved from 16bit to 24bit. 4 channels can be recorded when using an XLR adapter. Phase-difference AF is not installed, but AF is much better. The AF calculation speed has tripled, the background omission and tracking performance have been greatly improved, and the AF speed has also become considerably faster. There are 315 AF points in the full area. Human, face / pupil, animal + human subject recognition can be used in all AF modes. The focus range can be set with the focus limiter.
If confirmed, video codec specs are these:
Definitely won't fit into old housings.
Would be too good to be trueDefinitely won't fit into old housings.
