Ikelite DS-125 & DS-160 combination with TTL?
Started by Jolly ·
  1. Hi,
    using a DS-125 & DS-160 together - I wonder if this combination is fine for an Ikelite TTL-converter upgrade?
    From my understanding strobe power output is controlled by burning time (not by intensity). If DS-160 & DS-125 have the same bulb, they would output same amount of light with the same time frame. As TTL controls the burning time it should work without problems? Has someone run different DS (125/160/161/...) strobe combos with TTL?
    Thanx
    Julian
  2. The key question is if the strobes use the same xenon flash tube or not.  The other thing that may impact is if the electronics are the same, bigger capacitors may dump their charge faster.  The same question was asked a few years back but no conclusive answer.
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjQs8_kmr_2AhUNS2wGHdK9Ca0QrAIoAXoECAIQAg&url=https%3A%2F%2Fwetpixel.com%2Fforums%2Findex.php%3F%2Ftopic%2F25903-ikelite-ds125-and-the-ds160-on-one-set%2F&usg=AOvVaw3Ol4dlDA1vA7Gs4BzQByCY
  3. The capacitors are indeed bigger in terms of capacity because of the higher juice rating (higher full dump output by longer burning duration). Assuming the tubes are identical that does not lead to brighter light output (within the same burning duration) because I expect the capacitors voltage rating is unchanged (only higher capacity).
    Ikelite says using DS125/160 with TTL „is fine“.
  4. DS125 and DS160 have similar TTL-curve in main part of TTL control range.  I checked this pair using UWT TTL-converter, some difference in DS125/DS160 lighting existed, but was acceptable.
    Edited by Pavel Kolpakov
    seems to be confirmed in this post from a few years back:
    View archived post in: Strobe "Shutter speed"
    OK thanx. Some difference in amount of light?
    Some difference exists, because of capacitors, but as for me it is acceptable for most of cases TTL shooting.
    If manually perform a full energy flash discharge, the difference can be more visible.
    But in case of aged strobes like DS125, you also even can see a difference between 2 strobes just because of concrete strobe capacitors condition / age. Electrolytic capacitors are not very stable in longtime usage.
  8. Manual full dump shows capacitor's capacity difference (power rating). Approximately half f-stop. Within DS-125 power range TTL response shouldn't differ by design. Small differences due to aged capacitors / serial spread / etc. is fine for me as this would apply to combined identical strobe models as well.
