Strobe Triggers for Sony Mirrorless
Started by Interceptor121 ·
  • 23Posts
  • 23Replies
  1. Turtle is a good trigger but they need to improve the on/off switch in the next version
  2. I realised this thread should have been posted into light section if a moderator can move it please
    As if by magic...... done!
  4. Wow, nice write up, thanks.  I was going to buy the Turtle TTL version even though I never expected to use TTL, but now I see the non-TTL version has an advantage (besides simply being cheaper).
  5. Wow, nice write up, thanks.  I was going to buy the Turtle TTL version even though I never expected to use TTL, but now I see the non-TTL version has an advantage (besides simply being cheaper).
    The turtle TTL is the most complete trigger on the market however if you don’t need TTL or multishot programming it is another step to take into account
  6. My question is related to this older tread, so I post it here:
    I have Sony A7R5 and just started to use it UW. I went for the Nauticam manual flash trigger, as it seems to me to be the most compact one. I intend to buy an additional, second, trigger later (from Turtle or UW-technics), to have two flash triggers with me, for redundancy.
    I set the shutter speed to 1/250s and the flash mode to "slow sync" (as far as I understand this flowery designation means front curtain; according to the Nauticam manual their trigger does not perform rear curtain)...
    After the dive I noticed the shutter in the upper rim of the photos (the waters are cold here and I was very busy with the new camera/housing and did not notice it during the dive). Did I do something wrong and need to adjust different, or is 1/250 just too fast and I have to reduce to 1/200, or even lower?
    Thanks, Wolfgang
    Thanks, Wolfgang
    The correct setting for fron curtain is Fill-flash
    Slow sync is intended to be shot in aperture priority to allow the flash to drop below 1/60
    Set the flash to fill flash and try again
    Thanks Massimo for the comment...
    Are you sure "Fill flash" is the right mode? Is this mode not working with a preflash for TTL measurement, before the actual flash (related to the shutter) is released?
    But I can easily try it out...
    Wolfgang
    Wolfgang
    I am sure. All flash modes are ttl but your trigger will ignore it
    I tested it out on land (the rig is assembled, it is raining here and we are waiting for nicer weather until we go for a dive)...
    You were right, also fill flash works. Unfortunately the shutter still shows up at the top of the image, no difference to "slow sync"...
    1/200 works in both modes, maybe this is the fastest speed that can be achieved with Nauticam trigger and A7R5 (?)...
    Wolfgang
    Edited by Architeuthis
    Wolfgang
    To understand if the trigger is introducing a lag to react you would need to use another flash on the hot shoe or a sync cord
    The camera sync speed is definitely 1/250 and on my GH5 the nauticam trigger works to 1/400 which is higher than the official sync speed
    On our EM1II the (other) Nauticam trigger works up to 1/500, but the shutter is bigger in FF, this is another story...
    Wolfgang
    I recall reading somewhere that you need a TTL-capable trigger to get 1/250s flash sync on A7 series cameras; something to do with very precise timings required for it to work. With a manual trigger the quoted sync speed is 1/160s.
    Wolfgang
    That was to understand if the trigger adds a lag. The camera will always sync at the declared x-sync using either a sync chord or a manual flash connected to the hot shoe
    Normally Nauticam triggers are very responsive so if the limit is introduced by the camera they may even overcome it
    My Turtle trigger works up to 1/400 as per manual with mechanical shutter in speed priority, 1/320 in mechannical and 1/200 in electronic
    The Turtle trigger might report to the camera, the same as a TTL trigger so the camera will then sync at the higher speed.  Manual triggers that can exceed the published sync just use the electrical contacts without reporting their presence to the camera.
    Nauticam web page
    https://www.nauticam.com/products/mini-flash-trigger-for-sony-compatible-with-na-a7-a7ii-a9
    Please note that with the Sony a7R IV, a7 IV and a7R V there is slight black banding at the top of the frame when using the max sync speed of 1/250.  There is no banding at 1/200.
    For the Sony a1, the max sync speed of 1/400 is supported with the 26302 Mini Flash Trigger.
    Note that here the older Turtle triggers seem to be compared. TRT has released Turtle 2 TTL version. I cannot speak for Sony, but I just had the Olympus one delivered (Turtle 2 TTL) - all I need to do via USB is strobe selection. Once done, I can set every other setting (curtains, TTL/manual, even strobe power, up to 1/128) via camera, no need for USB anymore.
    One thing I am not sure is the HSS mode - for Retra at least there appears to be two entries in strobe selection, one specifically mentioning HSS. I am using Z240s, hence that is not a concern for me, but otherwise emailing Balzas might help - been talking to him extensively and he responds very fast, often within an hour.
    Edited by makar0n
    In the Sony system the camera never fires the strobe in manual so the programming is done in a way that ttl is ignored by the trigger
    This step requires programming and is the biggest inconvenience with the Sony TTL trigger
    And 1/500s in APS-C crop mode, but you're not using an A7 camera, you're using an A1.
