10.5mm Lens Advice
Started by Ron Boyes ·
  • 23Posts
  • 23Replies
10.5mm Lens Advice
  1. 10.5mm Lens Advice
    Hi Guys,
    Well I have taken the plunge and will concerntrate on WA rather than macro for my next trip (Ocean Rover).
    The setup I am using is a D100 in a Subal Housing with 2 x Inon Z220, I have a 12-24 zoom and will purchase a 10.5 next week.
    I would appreciate any tips in getting upto speed with this speciality lens.
    thanks
    ron
  2. me too
  3. Get very, very, very close to your subjects :(
    Try your strobes a little closer in than for normal WA and aim dead ahead or even a little pointed out ;)
    Once you figure out the lighting, you will love this lens
    Karl
  4. It's great for over-under shots as well so spit on your dome and get a few of those type shots if you get a chance.
  5. Get close....real close.
  6. Strobe placement is very important. I use dual SB105's but the same principles would apply regardless of the type used. The front of the flash head needs to be behind the focal plane. I pull mine back, in and pointed slightly out. Here are a couple of images that should give you a good idea of the placement.
  7. Hi,
    Could you explain little bit your flash placement ?
    Aren´t you get shadow from housing if flashes are like that ?
    I suppose you are using diffuser even they wasn´t in pics ?
    JM
  8. JM, backing off the flash is essential with fisheye so they don't appear in the shot, and believe me they do show up even when you are carefull. I've included a diagram, if you don't want it in the shot, stick it behind the line.
  9. Well it would be better if i included said image. Doe ! :?
  10. Ron -
    You are probably already familiar with this but marine camera has some info on the 12-24 at:
    http://www.marinecamera.com/index.html
    Click on article in red at bottom "getting wider"
    M.
  11. Hi,
    JM
    The photo is accurate. The housing does not block the light from the strobe. You can check it underwater by holding the housing in front of your face and making sure you can see the strobe reflectors. I don't use diffusers because I tend to lose them.
  12. Well it would be better if i included said image. Doe ! :?
    Great illustration but it doesn't tell the whole story. Because the 10.5 is such a wide lens the right and left edges of the frame will be very close to the strobes if you configure them exactly as shown in your diagram. I was getting hot spots when I first started using the 10.5 at the edges until I learned that I not only needed to position the strobes behind the the housing but I also needed to pull them in closer than I would have with a regular wide-angle lens.
  13. Point taken Larry, this is a shot from a while back when I first got the lens, sort of a what not to do picture :?
  14. I love it! This is the exact same thing that I did on my first dive w/ the 10.5. If you pull your strobes down, you can get them out of the frame, as the fisheye is only 180 degrees from corner to corner.
  15. That's not too bad Jean; at least your fins and camera lanyard haven't made an appearance.
  16. Nah! Andrew, the fins I always keep for open water :wink: but good idea for the lanyard, i'll install one for my trip to bermuda and try to get a trio, fins, strobe and lanyards :)
    P.S. note the subtle dome shade appearing in the upper corner, the shade was off center by a 1/4'', VERY WIDE lens...
  17. Thanks for the diagrams and example photos...this is incredibly useful for me. Anyone got some undefished (is that a word), uncropped 10.5mm shots through the Ike dome they'd be willing to post?
  18. HI Chris, check this link for a review of the 10.5mm I did a while back, I'm sorry if they are not taken trough a Ikelite, but my allegiance lies elsewhere, nonetheless the shot are trough an Aquatica 8” dome, in regard to defishing (Hell! if the verb doesn’t exist let us Wetpixel member stake claim to it) I’ve had limited success with Nikon Capture, it all comes down to the edges contents, any kind of identifiable texture and your up that proverbial creek!
    http://wetpixel.com/module-pagesetter-view...-3-pid-34.phtml
    Regards
  19. A couple or three shots with the 10.5mm with Ike 5503.15 dome...uncropped w/o perspective control
    And a topside just for fun
    Karl
  20. A couple or three shots with the 10.5mm with Ike 5503.15 dome...uncropped w/o perspective control
    Karl
    Thanks! These are great shots, and just the sort of encouragement/inspiration I was looking for!
