Lens for Canon D20
Started by emdru ·
  • 36Posts
  • 36Replies
Lens for Canon D20
  1. Lens for Canon D20
    Hello all. I am an experienced above water photographer and diver, but new to underwater photography. I have a D20 with a wide assortment of zoom lens. I am planning to get the Ikelite housing with ettl capablility and the D 125 strobe. My question is what is the best all around lens to take fish portraits and critter close-ups. I assume macro, but what focal length. Ikelite doesn't appear to make a port for my Canon 28-135 IS USM zoom, and I don't have a prime. A friend of mine used a Nikon 60 mm Macro with a D-70 on a recent dive and was very happy, but it seems that the only choice for the canon is a 50 or 100 mm macro.
    Thoughts?
    Ed Druy
  2. As one who's extensively used the 10D underwater, my suggestion would be the EF-28-405 f3.5-4.5 USM. I use a Subal so don't know if Ike supports this lens, but I've made 20x30 blow-ups from my images made with this lens that will blow your socks off. Shot behind a dome port you're covered from small sharks/seals to 1:2 macro if you use an external diopter like the one sold at http://www.nexusamerica.com
    Stewart
  3. Canon has just announced a new EF-S 60mm f2.8 USM macro lens that will work on the 20D, you should look into that. It will be available in April.
  4. Do you mean the 28-105 mm?
  5. OOPs! Yes, sorry, yes the 28-105mm, Make sure you don't get the cheaper 3.5-5.6 version!
    s.
  6. I also like the tiny 24-85 USM. Since you're using Ikelite, you're a bit limited in your port choices, or I'd recommend the 70-200 F4L
  7. I am leaning toward Ikelite because of cost - other housings seem to be twice the price. Are there companies that will make ports that will attach to the Ike housing, but will give me the flexibility of lens choices that Ikelite doesn't?
    Thanks to everyone for their responses.
    Ed Druy
  8. Canon's new EF-S 60mm USM Macro can do 1:1...
    ~Matt Segal
  9. Canon's new EF-S 60mm USM Macro can do 1:1...
    yet another terrific EF-S lens to stick it to us non-EF-S mount Canon owners ;)
  10. I used the 50mm Sigma and I can recommended it, as well!
  11. I guess the new EF-S 60 mm macro is good if you don't see a 1.3x of FF sensor in your near to mid future. I personally am staying away from EF-S lenses (shooting 20D) so I can carry my lenses forward (too bad I can't say the same about the Subal housing!).
  12. The 50/60mm macro lens is just right for fish portraits. I also use the 60mm on the D70 and I get my best results with this lens. A mid-range zoom will give you a similar focal length but it doesn't have the same sharpness or magnification for close shots that you get with a macro prime.
    If you think you will be in the market for a full-frame camera in the next few years (look into your crystal ball, these are in the 5K+ bracket now but maybe will come down eventually) then I would look into the Sigma 50mm. The newly announced Canon 60mm does 1:1 and has a USM for fast focusing. Its very interesting but is limited to digital. If you want versitility go for the Sigma 50mm, it does 1:1 and works on full frame. The Canon 50mm doesn't do 1:1 without diopters.
    For real close ups you want the Canon 100mm USM. This focal length has the same magnification as the 50/60mm but gives you a bit more working distance between you and the subject. You need this if you want to get close for good magnification and not spook the critter and also so that you can effectively light it. At 50mm it really isn't practical to get close enough for 1:1 and even if you did you would have more trouble keeping shadows out of the frame than you would at 100.
    A bit of perspective is needed here. Ikelite offers ports for just about every lens you will want underwater. Unless you have some very exotic needs you won't have a problem here.
  13. Yeah, like that "exotic" Sigma 12-24 for your 10D...
  14. My Nikkor 12-24mm fits just fine....
  15. Hi, I agree - it sounds like it works for you.
    Sure, the 12-24 fits, but you have to take the lens off if you want to take the camera out of the housing, right? And you have to take the camera out of the housing to change the CF card, right? I change the CF card after every dive and I do 5 dives a day. That's 5 chances to drip water on my camera, put the port on wrong, mess up an o-ring, etc. If you're a Canon owner and you have the 10-22, the setup is awesome. You don't have to take the camera out as you can slightly slide the housing open and get at the card from the side of the camera. If you have a 10D, you just don't get to use a wideangle zoom period - and I know there are a lot of 10D's around - which is a bummer.
    Nothing against Ikelite - I have their 20D housing and it's excellent - but each housing has its pros and cons. Whether it's price, port selection, ease of use, weight, etc.
  16. Speaking of 10-22 I really have not heard a lot about it yet. How many people hear have one and do they have some experiences to share?
  17. Speaking of 10-22 I really have not heard a lot about it yet. How many people hear have one and do they have some experiences to share?
    I have one and got the Aquatica zoom ring for it ( thanks Blake ), but have not had time to dive. It's still ski season. ;)
  18. Speaking of 10-22 I really have not heard a lot about it yet. How many people hear have one and do they have some experiences to share?
    I have one and got the Aquatica zoom ring for it ( thanks Blake ), but have not had time to dive. It's still ski season. :D
    Even topside I would be curious. Like a mountain scene... ;)
  19. Or a broken-leg rescue scene...:-)
