Nikon 12-24mm
Started by Alex_Mustard ·
  • 45Posts
  • 45Replies
Nikon 12-24mm
  1. Alex
    I see that on the end you have purchase a Nikon 12-24mm.
    Why have you change your mind ?
  2. Easy! I didn't have to pay for it!
    I swapped it with a friend for a 16mm (I had two - having been given an extra one). Its not a permanent exchange - its just until one of us wants the other lens back, which will probably be never!
    I can't afford to buy any glass at the moment, but if I had any money at the moment I would buy a Sigma 150mm macro!
  3. Nice swap
    Me meather have the money att the moment for second lens. Maybe its better so becauce I will learn to use my 10.5mm. Extrem wide angle is a heavy thing and I have Zero experience with DSLR under water. It will be hard work to master the 10.5 lens
    btw you can write a article about shooting with the 10.5. :-)
    Sigma 150mm Macro!! Are you going to shoot the structure off a fishs pupil :-)
    My next lens is I think the 16mm or 105mm. I hope tha Nikon will come with some new digital lenses like the 10,5
    Lambis
  4. Alex - did you consider the Nikkor 14mm? - or is that not wide enough given the crop factor?
    It's a great bit of glass and works well underwater, providing the dome is right -although it does suffer defocussed edges when wider than F8 on film (but the crop should take care of that)
    Edited by Steve Jones
  5. Never thought of that lens, Steve - although it has been on my radar recently because it takes the same size Magic Filter as the 10.5mm! Its a good suggestion, although I think it is quite pricey? Which tends to put off a cheap-skate like me!
    Personally I think that the 16mm is hard to beat as a wide angle for big animals on a DX sensor Nikon. I used it almost exclusively when I was in (your fave spot) S. Ari a couple of months ago.
    I still have mixed feelings about the 12-24mm. I guess I'll know a bit more once I have done a few shoots with it in my lens bag. But not snapping until I head to Bali in September. I do think that the 12-24mm is going to be excellent for coral spawning in the Caribbean later in that month.
