woody's diopter on Aquatica macro port
Started by herbko ·
  • 11Posts
  • 11Replies
  1. Anybody knows if it can be made to fit? If so which size 90mm, 100mm or 110mm?
  2. I'm sure it will fit Aquatica...e-mail Woody for the correct size....info@nexusamerica.com
    Karl
  3. I'm sure it will fit Aquatica...e-mail Woody for the correct size....info@nexusamerica.com
    Karl
    They haven't anwsered my email in a couple of days, and calls to the number listed on their website leads to a fax tone after a couple rings.
    Any ideas on how to contact them?
    Is there another place to get a Woody's diopter?
  4. Herb,
    Woody is a one-man show there so if he's out traveling or at a show, he may not answer. Marine Camera Distributors also advertises the diopter so if you need it right away you might give them a call.
    Mike
    Edited by MikeO
  5. Did a bit of checking and my sources tell me that Woody is in the Philippines until the 30th . . .
    Mike
  6. Yes, he's diving in the Philippines at the moment, however Woody should be back online by this weekend, he'll be in an area where he'll be sipping mango shakes with rum or a cold San Miguel beer at the bar and have a wifi connection to boot! Lucky b----rd! :D
    Stu
  7. Lucky Woody! Thanks for the info. I ordered one from Marine Camera.
  8. Which one is it Herb? I had asked about this about a year ago but they said it would not fit.
  9. CL-110 doesn't fit without modification, but I think Mike O was on to something long ago about buying generic caps from Niagra Rubber and refitting them to the diopter.
  10. The guy at Marine Camera doesn't know anything about Aquatica ports. I just bought the largest one, 110mm, to play with. I figure I'll find a way to make it fit.
    Mike. Have you got this worked out?
    Edited by herbko
  11. Yes. The actual glass diopter part is the exact same on all three sizes. If none of the three sizes fit (as was the case with my Sea&Sea custom macro port) then simply remove the diopter from the vinyl "boot"/cap/whatever you want to call it. Next, find a port cover that does fit (fron Niagara Caps and Plugs or from Aquatica) and cut a hole in the very center that matches the hole in the orignal diopter boot/cap/whatever. Insert glass diopter portion. In the picture below, the left boot is the original (I think a 100mm one). The boot on the right is the one I made by carving a hole out of the middle of my stock Sea&Sea macro port cover. The glass portion of the diopter is (needless to say) in the middle. It has a groove that accomodates the vinyl boot.
    Mike
    Edited by MikeO
