White balance (ing) underwater?
Started by Andi Voeltz ·
  • 24Posts
  • 24Replies
  1. I've had decent results setting the camera (a Canon S40) to "daylight" balance when shooting using ambient light -- this resulted in color that was the most like what you actually see through your mask. Auto-white balance doesn't work at all! Even still I tend to have to do lots of manipulation 'in post' to get things looking right.
    I'll be interested to see how my D60 handles the light u/w, can't wait oh boy oh boy.
  2. I have been using manual WB with my Canon S40 and have been very satisfied with it.
    Best to do so at every 5 meters of depth, otherwise your shots are a bit off.
    Lamps and flashes can't bu used when on manual though and other people's lamps look red in the picture (which is sometimes actually very nice)
    Some samples:
    http://www.rud-gr.com/temp3.htm
  3. If any of you are so fortunate to be closer to a good diving spot you should try a little test to see the results of different wb settings. I would be curious to see the results.
    So far it apears to be speedlight and point your camera at a slate but, if I read right, that was not actually compared to other settings underwater.
    I believe those too were the settings I used but I also need to go back and review the info to confirm.
  4. Isn't the idea of white balance to correct color for a given light source. And if so, shooting at white needs to be done while the lighting condition is active. I've opted to use HID lights and a white background. Lights are focused on my white object, therefore giving me a correct WB
