Which 3-4Mp camera for land & sea, on a budget?
Started by spearo ·
  • 24Posts
  • 24Replies
  1. I think the DSC-P93 is the way for me to go. It's actually called the DSC-P93A don't know if that makes any difference. Maybe I should get just a 512 card instead of a 1Gb. I like the idea of AA batteries instead of a proprietry pack.
    It would be really nice if this camera used standard SD card instead of sony pro card (those things are so expensive!).
    If I go the Sony DSC-P93A instead of the Canon Ixus 30 I will be paying an extra $130 is it worth the extra do you think?
    Edited by spearo
  2. If you want to take the camera in the water, then it stacks up like this: Ixus 30 has no housing and I seriously doubt it ever will. Sony P93 has a housing on the market now. So given that it is no go with the Canon and a definite yes with the Sony, I'd say it's probably worth the extra money. Oh, and you get 5MP instead of 3MP plus manual control if you need it . . .
    Mike
  3. I've got a DSC-P100 that I'm very happy with. Pics here: http://www.fauncefamily.net/album
    I'd skip the DSC-P93, it's going to have lag and other "last generation" issues. The DSC-P93 is actually several generations behind (P93-> P10 -> P100/120/150 (same cameras at 5/6/7 MP) -> P200)
    I'm planning on getting a P150 for my wife as it uses the same housing as the P100 and she's getting tired of the lag and response time on her P10. I'd get a P200, but there isn't a housing and according to Sony support desk, there isn't one on the horizon either unless the successor to the P200 uses the same body -- like the W series, the housing with introduced with the W7 and worked with the W5 and W1 since they use the same body.
    Inon also has a kit to allow their strobes and external lenses to work with the MPK-PHB housing that the P100/120/150 use so you have an easy "growth" path with that system.
    A 256MB Pro card holds just over 100 pics (I usually get about 110-115 before filling the card). I've played with the video part, but haven't really used it, so I don't have a clue how much video a 256MB card would hold.
    As someone else stated the battery in the P100 holds a charge pretty well. I typically fill the 256MB card on two dives and the battery is still going strong, even with forcing the internal flash on every shot. I've got 2 batteries and an external charger, so I swap batteries when I empty memory stick.
    Edited by mdfaunce
  4. I think you can go for a Sony DSC-P150 and the PHB housing it is really good
