Nikon D70 Firmware 2.0
Started by UWphotoNewbie ·
  • 13Posts
  • 13Replies
  1. Reports from DPREVIEW users who have upgraded are that the firmware does not affect white ballance of NEFS just as Nikon stated.
    Also some are claiming improved auto focus in all modes and improvements to noise performance at high ISO. These are completely unsubstantiated and not claimed by NIKON so you will have to see if this is irrational exuberance.
    Nikons' Statement:
    Issues addressed with firmware version 2.0
    Performance of the 5-area AF system has been improved (Dynamic area and Closest subject AF-area modes).
    Changes have been made to the design of menu displays.
    Page-size settings can now be applied from the camera with direct printing from a PictBridge-compatible printer.
    The number of exposures remaining, displayed in the control panel and viewfinder, when shooting at an image-quality setting of NEF (RAW) or NEF+JPEG Basic has been changed (the number is calculated based on the size of compressed RAW file).
    Maximum number of exposures displayed when a 256-MB CompactFlash memory card is used:
    Version 2.00:  NEF (RAW):  approx. 44 exposures; NEF+JPEG Basic:  approx. 39 exposures
    Version 1.03 or earlier:  NEF (RAW):  approx. 23 exposures; NEF+JPEG Basic:  approx. 21 exposures
    The default setting for camera clock has been changed from 2004.01.01 to 2005.01.01. Now you cannot set the clock back to a date before 2004.12.31.
    A problem that sometimes caused communication between the camera and computer to be unexpectedly terminated when using Nikon Capture Camera Control has been corrected. (Windows)
    Of these I think the improved autofocus and the fixed shot count are the most exciting. I never liked how the D70 handled shot count. I understood why it was like that but it was annoying.
  2. I herd from at list one that the improvement of the focus mechanism is well noticed.
    Personally I'll wait few days with it to see that there aren't any side effects.
    Edited by alto
  3. Thanks for the "heads up".....done :blink::huh:
    Karl
    Excellent
  5. Hi,
    I think AF is surely improved. It is fast & more accurate.
    Sam
  6. I am glad to hear that the white balance encryption is not part of the update. I would be very bothered if Nikon decided to include it as an "upgrade".
    David.
    PS. Karl, let us know if you see any "improvement" with the new firmware. B)
  7. Thanks for the heads up downloaded it and updated both camera bodies. Wish I would had this before my trip last week..oh well, thanks..
    Tony
  8. Somehting that's not quite clear in the Nikon D70 Firmware 2.0 Updgrade instructions: When copying the firmware to the memory card make sure to copy the "A" Firmware and "B" Firmware separately (or use two cards). If you copy both "A" and "B" Firmware to the card together then only the "B" Firmware will be updated.
  9. Somehting that's not quite clear in the Nikon D70 Firmware 2.0 Updgrade instructions: When copying the firmware to the memory card make sure to copy the "A" Firmware and "B" Firmware separately (or use two cards). If you copy both "A" and "B" Firmware to the card together then only the "B" Firmware will be updated.
    You have to copy first the A file and update the firmware, then delete this file from the card, copy the second one and update the B firmware.
    Since( as usual :blink: ) I didn’t finished to read all the instructions, I copied the 2 files and it updated me only the B firmware and then after I deleted the B file and ran the update again its updated the A also with no problem.
    Edited by alto
  10. Anyone know offhand how to quick-check your firmware version? I am pretty sure mine was updated when purchased back in March, but I want to be positive.
  11. Go to your menu....look up Firmware version
  12. Anyone know offhand how to quick-check your firmware version?  I am pretty sure mine was updated when purchased back in March, but I want to be positive.
    I doubt you have version 2.0. It was only released last week.
    Edited by anthp
