wide angle white balance
Started by red3 ·
  • 26Posts
  • 26Replies
  1. But don't trust my memory - check the manual!
    RAW makes it less essential to do this on stills while underwater because you can set the WB in ACR or equivalent.
    Read the manual!?!? Oh how anti manly that is... :o
    But guess i will dig it out of whatever box it is in and have a look
    So am working on PS at the moment and converting RAW files, however can't find an eyedropper for the WB in the PS RAW plug in. Maybe in Nikon Capture there is a WB eyedropper?
    What i usually do is once the image is in PS i go to curves and open the info box and then either set a black point (changed the default to 8) or a white point (changed that default to 244)
    Works pretty well most of the time, and definitely gets rid of the sort of cloudy sheen so often prevalent on images, especially scanned ones.
    Guess i am dragging this thread off topic now eh? oops
    Mike
  2. Mike see the attached image of where the dropper is.
    I don't see this as off topic at all. Lots of useful info being exchanged in this discussion. Keep it coming!
    p.s. Sorry about suggesting the manual. It was sunny here on Friday - a rare event in England - and clearly I wasn't thinking straight!
  3. Aha, cheers Alex! The labelling made me laugh too.
  4. Isn't this a bit technocratic?
    Despite a background in zoology and medicine (?!) I thought that this was an artistic endeavour?
    I've been using an entirely subjective method, shooting in RAW, optimising and converting to a Photoshop compatible format, and then using "channel mixer", usually swapping some green channel data into the red channel.
    Shallow reefs and sharks have come up very well, very comparable to URPro filtered images that I've seen, and avoiding the necessity of finding a white/neutral grey target.
    Perhaps I'll try the "objective" method too. The camera never lies (!).
  5. Have been reading this thread and wondered how far does the camera have to be from the slate to set white balance? I shoot an Olympus 5050 and am going to Galapagos in August. I have a Magic Filter and will try shooting ambient light (no strobes) on the strong current dives. With the Magic Filter, it says reset white balance every 2 meters, not a problem, easy on the 5050; will use wide angle. I put camera in housing (Lights and Motion) and tried outside to see if slate was big enough ... not quite large enough ... also, does it matter if I am zoomed out or do I have to be zoomed in? If zoomed out, I think it should be large enough .... :)
