Subal housing Canon 20D
Started by steph ·
  1. Hello,
    I am looking advice for setting up a Canon 20D in a Subal housing.
    I think subal housing comes with 2 handles and 2 flash plugs (nikonos V) by default ?
    I have 2 subtronic flash : does it sounds good ?
    Ok now for the port. :D
    I would like to use the EFS10-22 : I was ask to use the DP-FE2 + EXR50 + ring 4ZC065 (to use the zoom ring I presume).
    Does its seems ok ? Does it comes with a sunhood and also with a protective piece of neopren not to scratch it on the boat :D ?
    Now for the macro port :
    I have the EF 100 macro (the 'new' one which doesn't extend) and also have the Sigma 50macro (which extends :( )
    I would like to have (if possible) a port that does the 2. I made it with my UK-Germany housing with film so think it should be possible no ?
    One thing about that : I would like to have the focus ring to work on my 100 (because sometime it's tricky). Can this be achieved without a knob on the port... just with a ring ?
    thanks a lot for helping :D
    Stéphane
    Taken 2 weeks ago in Martinique see the Rest
  2. Now for the macro port :
    I have the EF 100 macro (the 'new' one which doesn't extend) and also have the Sigma 50macro (which extends  :D )
    Stéphane
    I use the 20D in the Subal housing along with both the Sigma 50 EX DG macro and the Canon 100 mm (non-extending) USM macro. The FP-90 flat port works well for the Sigma 50. Adding a 15 mm extension ring just accomodates the Canon 100. If I wanted to add a filter or diopter to the 100 mm I would need a deeper extension.
    I have not felt the need for manual focus. As long as I am using a focus light the lens does not hunt. If I want to adjust focus a bit I move the camera a millimeter or two forward or back. This is easier to me than reaching my hand around to the focus knob.
    For wide-angle shots I use the Canon 15 mm FE behind an FE2 port with no extensions so I can't help you with the 10-22 mm zoom. I bought my FE2 off ebay. It did have a sunhood but not a neoprene cover. I bought the cover at Backscatter.
    Also, my Subal housing shipped from Austria with 2 handles and two Nikonos-style 5-pin sockets. I believe this is standard.
    -Brad
    Edited by BradDB
  3. Thank for your answer Brad !
    The trick with the extension ring on the macro port is just what I was looking for !
    How looks 15mm fisheye pictures on the 1.6x cropped sensor ?
    How wide does it looks ? Have you got picture ?
    Thanks for your help
    Regards
    Stéphane
  4. How looks 15mm fisheye pictures on the 1.6x cropped sensor ?
    Heres one I submitted for this past Saturday's Monterey Beach Dive Photo Competition, Diver category. This shot did not win but I like it better than my shot that did win.
    It's been downsized and cropped a bit on the bottom to take it from 480x720 to 480x640. The width and the top portion are not cropped.
    -Brad
