East wall on Elphinstone
Started by Pedda ·
  1. Hi,
    I’m having trouble to get my wide angle pictures up to the same standard as my macro pictures but I like this one.
    Picture is taken on 18 meters depth with a D70 and 18-70mm @ 18mm. One single S&S YS-120 flash on full power is used. Shutter speed 1/125 and F-Stop 7.1.
    I’ve changed the White balance and increased the contrast in ACR.
    What do you think?
    Peter
  2. It is nice. I haven't seen any more of yout pictures - but for wide angle you need to think about your lighting more.
    To start with try to ensure that the foreground subject, that you intend to illuminate is parallel to your strobes. This will insure that it is illuminated evenly. Such images will look fine - if a bit dull, but once you have this right then you can start to bend this rule to create more interesting images.
    Edited by Alex_Mustard
  3. Peter, nice shot.....good job of balancing ambient and foreground light
    Karl
  4. Nice! Good color and light, I like the composition too. Thank you for sharing :D
