20D & Aquatica samples?
Started by Dakine ·
  • 16Posts
  • 16Replies
  1. Anyone using the 20D in the Aquatica housing? I would like to see some pictures so I know what to expect.
    I've spent a lot of time browsing though this forum but couldn't find much.
    How does the 8inch dome perform compared to the more expensive options from subal etc?
    Aloha,
    Ryan
  2. I use it and here are the photos http://www.digitaldiver.biz
    I also have the 8ich dome and to compare, well it's the same size as the subal 8 inch dome but the dome shade is massive!
  3. I'm using the 10-22mm and the 100mm macro, love the 8inch dome, dome shade is a must have. Pictures after 4/25/2005 at
    http://lionfish.us
    are 20d pictures. Next night dive will be with the 50mm F1.8 (it's been a little surgey for the 100mm macro lately.)
  4. Thanks Guys, very nice pictures!
    Great colors and lighting.
    How would you judge the sharpness of the dome?
    I can't really tell from the small samples.
    No need to post 100% crops just tell me it's good and I'll be happy :D
  5. My 10-22 is fuzzy at the corners at 10mm (it's a little fuzzy unhoused, and it seems a bit worse, but I may just be shooting closer.) If I zoom in a bit (14mm or so) the fuzzy goes away.
    Some of the color credit goes to the Nikonos SB104 I'm borrowing right now.
    Dan
  6. Fabio,
    Have you used your 70-200 F4L underwater?
  7. Hi James,
    not yet, but I will do in few days when will arrive my extension ring for the aquatica port. For while I'm doing some tests with close-up filters +3 and +4 on land. Tomorrow I will get an Kenko extension tube 12mm and I will try it to reduce the focus distance. did you get good results with this lens uw ?
    Regards
  8. I haven't tried it yet either. I think it will be good with a +1 diopter.
  9. I did not use with +1 close-up, with +3 or +4 the AF doesn't work well. I ordered an extension tube to try to focus close wihout lost the AF.
    Regards
  10. Thanks Fabio, It's really nice to see those detailed images of the housing.
    I had no idea that you could fit a 70-200 in there. Does anyone know if they make an extension long enough for the 300 f/4L IS ? (8.7x3.5)
    Aloha,
    Ryan
  11. Famorim,
    Are you using the wide-angle or the fisheye dome shade when you shoot with the Sigma 15mm fisheye?
    Ken
  12. Hi Ken,
    I'm using a dome shade for fisheye lenses(#18480) without any problem.
  13. Thanks Fabio, It's really nice to see those detailed images of the housing.
    Aloha,
    Ryan
    Ryan,
    there are some long extension rings to Aquatica's flat port, look at that examples:
    #18454-3 3/4 inches
    #18457-2 1/4 inches
    #18458-3 inches
    Best Regards
  14. Ryan,
    You would not want to shoot the 300mm underwater. A better alternative would be a Sigma 150mm F2.8 w/ a 2x teleconverter.
    The 70-200 is the same size as the Nikon 70-180 which is easy to house in Aquatica.
    HTH
    James Wiseman
  15. Yeah, I figured 300 would be a bit much underwater. (Although that lens does have a really short focus distance)
    I started to wonder if it would fit since I also shoot a lot of (surface) water sports and that would be a great if it could double as a splash housing.
    Is it possible to stack those extension rings??
    What is the inside diameter of the flat port?
    Ryan
