Subal Ext Ring
Started by Ron Boyes ·
Subal Ext Ring
  1. Hi All,
    Subal ND2 Housing with FE-2 Dome using 17-55DX lens -what extension ring is required?
    Is the use of a Dioptre required?
    ron
  2. Extension ring 70 (70mm), no diopter. I am using the same set-up. BTW, you can find this info also on Subal's webpage (www.subal.com)
  3. thanks
    ron
  4. Extension ring 70 (70mm), no diopter. I am using the same set-up. BTW, you can find this info also on Subal's webpage (www.subal.com)
    Wondering if any one has a link to the elusive port / extension ring / diopeter guide / chart. ciopy will do nicely )
    I have searched around the port page and can find nothing other than a quick mention that it is available
    To quote the subal page " The complete range of ports can be found on a separate up to date lens/port chart.
    I must get some new glasses....................
    Peter the blind
