FS: Pelican 1610 with Padded Dividers
Started by cmm1970 ·
  1. Tempting......
    You may be interested that I've just hoiked a Pelican 1510 around the world and had no problems getting it on as cabin baggage on 19 flights. But its a bit smaller than the 1610.
    Good luck with the sale.
  2. ... I've just hoiked a Pelican 1510 around the world and had no problems getting it on as cabin baggage on 19 flights. But its a bit smaller than the 1610.
    The 1610 is MUCH larger, and could NEVER be used as a carry-on (even if you could fit it through the passenger security screening XRAY machine, which you never could, they'd look at you like you were nuts when you arrived at the gate to board!). :D
    I've used a 1610 as my primary checked photo bag for a few years, though, and it works well for that, especially if (as someone here suggested not long ago) you take the handle and wheels off, which shaves several pounds off the weight.
  3. I've just hoiked a Pelican 1510 around the world and had no problems getting it on as cabin baggage on 19 flights. But its a bit smaller than the 1610.
    In my last flights with carry-on in some of the check-ins they weigh it and made problems if its was more then 20 pounds, the 1510 weight 14 pounds, its not have to much weight to the equipment that way doesn't it?
  4. I must have been lucky; it was never weighed. It was packed with my housing, two strobes, two lenses, extention tubes, batteries etc etc. I usually tried to carry it to make it look as though it weighed nothing. Of course, I now have a pinched nerve in my shoulder :D
