Hi Alex, I love the system, I had only one problem, sometimes the switch on the housing for the back command dial doesn't work. I always change the aperture of the sub command dial (front) and speed on the main command dial (back), but I couldn't do it today. I quickly inverted sub/main dials in the menu and was able to change the aperture, but I don't want to have to do this all the time. I think I will glue an additional layer of rubber on the place where the housing control touches the dial. Have you ever had this problem?
All the rest works perfectly. I didn't cut my green (ready light) wire, and the Ikelite flashes work fine, I took about 150 photos, the flashes fired every time and the picture was always written to the camera. I think it is because my second flash (100a) is a lot slower to recharge than the main flash (200), so they don't "compete" for ready light. I think that when you have two flashes and the second (the one on the right) recharges and sends the ready light signal first is when the problems occur. I say this because I accidentally turned on the second flash first and the camera (and flash) acted really weird. Everything was solved by turning it off, turning the main flash on and turning the second flash back on.
Conditions didn't improve, and there is still a lot of suspension in the water (vis. was about 10ft today), but I will post some more pictures later.
Luiz
