I am still quite new on Underwater DSLR. I am trying to shoot manually to have full control but as a freediver and available light fan I have some limitations
First I like to tell you the kind off photos that i like to shoot are most off the time in clear blue water (Mediterian and red Sea) with good visability.
The photos are WA (10,5 & 16mm Nikon lens) of freedivers, spreafishers dolfins and big mamals (If I see one :-) )and background only the BIG BLUE or some rif
Normaly with Strobes this will be not a problem. Manual exposure - spot metering the background use the strobes for the subject.
But without strobes i have follow problems
If I use spot metering (background water) my subject may be unterexposed
If I use spot metering on the subject the background water will not have the RIGHT color
Is it better to metering on the subject and use Fstops to archive the color of the background water?.
Then we have Focus. I still dont know if i will use AF-C & AF-S or AF Area Single , Dynamic
The only think that i know is that I like to use the shutter to look the exposuse. But if I whant to re-frame the shot only AF-C focus work.
Peters Schulz manual focus trick is a good solution but i havent test it very mutch
and I dont know if its work with the 16mm Nikon.
May I am wrong or I miss something but any tips and suggestions are welcome
There is something that work great!!!! White Balance (Yes I shoot RAW but stil i think that correct whtie balance help alot)
Auto & Manual white balance with the nikon D70s is very easy. If i have not some sand to doit, I use a grey card or I put a pair off fins where i have paint the one white :-)
Lambis
