UNIVERSAL STROBE CABLE
Started by Viz'art ·
  • 31Posts
  • 31Replies
  1. Ever had cable problem and every body around you has a different cable set-up.
    I'm just trowing a rock in the pond here, but aren't we ready as a community to standarize things a bit, how about a universal cable (call it DIN) identical at both end with 7 pin for future option such as modeling light, the bulkhead would be a 7 contacts affair used by both on the housing and on the strobe body. I know it's a pipe dream but, imagine a molded cable that would allow swapping accross different brand of flashes and housings. we are at a turning point in flash technology and it's only a matter of time before we have strobes with built-in whatever-TTL, if the strobe manufacturer could only agree on a standard protocol and attribution for the layout of the pins and contacts and even the number of thoses. that would help the end user a lot. I figure with seven or maybe eight pin you can have access to all the function of the differents manufacturer. We could even get cables from manufacturer X to put on housing from manufacturer Y and strobe from manufacturer Z. that mean choice of quality in the selection.
    What if you have an old system, no problem, get the Nikonos to DIN or the Ikelite to DIN adapter.
    Here is a few sketches for the creative mind...
  2. OH! and why not double O-rings at each end while were at it !
  3. It should be optical. O-rings are optional; duct tape will do in an emergency. No more flooding problems; lighter, smaller and easier to manage. The technology for doing it this way has been here for a long time. It shouldn't be that hard IF we can get all the equipment makers to standardize. Inon has taken a good first step.
    Edited by herbko
  4. I tought about optical fiber, but you need a transmitter or a built in flash to send a signal and a receiver to decode in the flash, it might be too much for the more craftmanship oriented manufacturer and they are the first one along with the housing manufacturers that should get on board for a thing like this. benefit are lower cost due to manufacturing a single cable design, and add to this profit maker like adapters to convert other cables from Nikonos, Sea&Sea, Ikelite etc...
    One thing is sure, Nobody in his/her right mind want's to fabricate the Nikonos V connector if they can afford not to. those pesky spring loaded pins are a nightmare to everybody from the manufacturer to, more important, the user.
    The other thing, 5 wire doesn't cut it anymore, the electronic are getting more complex and underwater photography is not for Nikon only anymore. having more wires (better yet, optical fiber) will make life easier for everyone, you just have to agree which of the camera maker get which pin, #1 always for X sync, #2 for ground and the five or six others for whatever function needed by the camera makers.
  5. I'm convinced that optical is the way to go. The Inon optical connectors work well if you don't care about xTTL, and it's does not cost that much more than a set of cables, and that's for an external unit. If you start from scratch and build that into the housing, you'll probably end up saving money.
    The electrical to optical conversion is simple compared to decoding the xTTL, if the housing and strobe makers don't want the task, they can contract it out to people like Matthias.
    Edited by herbko
  6. Two wires only for me please (X and ground). Cut down on the bulk and they would be cheaper and more flexible. Also while I am wishing - I would like one that is 8-10ft long. Wet connectors on the housing.
    Joking/wishing aside - its a good idea to standardise. The Nikonos cable was standard for a long time, pity that people have been going away from it, often without good reason. I do understand the need for 6 pins for Canon.
  7. Alex, having a standard cable would open the market for little accessories like wet connector converter and extension cord etc. i would love to see some creative engineering mind going at this project, Mathias, Haben ze en project !
    Edited by Viz'art
  8. Two wires only for me please (X and ground). Cut down on the bulk and they would be cheaper and more flexible. Also while I am wishing - I would like one that is 8-10ft long. Wet connectors on the housing.
    The best underwater plugable connectors that I have used are made by Impulse. I use them for suit heaters, video lights and other underwater battery to whatever connectors. I dove with a fellow earlier this year who uses them on his housing for flash sync. The series that I use most can b seen at
    http://www.impulse-ent.com/pdfs/IE2.pdf
    They are about $50 per connector.
  9. Wow!, I used those on my old Aquatica A3 and oceanic strobes, simple and elegant solution, takes a licking and keep on ticking kind of technology, they are called EO or something. Also available at the time there were the one that Sea&Sea was using many moon ago. That also was a bullet proof solution.
    Edited by Viz'art
  10. SOLD! I'll take 4 DIN cords please.
    (stands up in back of room and waves checkbook over his head)
    ...This will never work... ideas that make sense...
    All the best, James
    Edited by fdog
  11. I think this will work, because WE can make the standard.
    So when it is availible we can all start using it and the manufacturers will follow.
  12. Subconn already build a whole series of connectors (2 core to a great many - I haven't got their manual in front of me) swappable underwater (each contact has its own 'O' ring), rated to immense depth and with a minimum plug/unplug reliability specification. Some of these could be used for flash - snag is the cost! And cables can be customised!
  13. maybe I'm missing something here, but isn't the S6 system already thinking along these lines?
    Rugged cables, DIN type fittings, 6 wires (ok, not quite 7) and multiple o-ring seals?
    I think there is a wet version of the S6 out also, which allows TTL flash interchange underwater. The 6th connector allows for modelling light control between compatible housing (Seacam etc.) and flashes such as Subtronic.
    Paul - are these the same as the Subconn ones?
  14. Wow!, I used those on my old Aquatica A3 and oceanic strobes, simple and elegant solution, takes a licking and keep on ticking kind of technology, they are called EO or something. Also available at the time there were the one that Sea&Sea was using many moon ago. That also was a bullet proof solution.
    I really don't like the EO connectors. I find that the Impulse connectors make a much more reliable connection.
  15. I haven't looked into the wet connector system as suppliable by Seacam as I've never been asked for one - from the Seacam brochure it does look as though a Subconn connector can be used though. Trouble is the high cost - I can't remember prices as I looked ito this several years ago but then you'd be talking several hundreds of pounds to fit a subcon connector and few people seem to think that the advantage is worth having for that knid of money!
    I use a mix of S6 and Nik5 sockets on my own housing - but all running manually. Perhaps I'll look into two core Subconns and see what is possible, although a brief look at their folder indicates that they use a 7/16" x 20UNF thread whilst I think that Nik 2 sockets run a roughly a 10mm diameter threaded hole. So this may be tricky depending on housing and your thoughts on enlarging or drilling another hole!
  16. Hello,
    Well ... I am an ingineer and I have to say ... I don't think a standard will hapen. All the companies want you to buy their cables for $50 - $100 not for $2.99 from Radio Shack...
    Just look at all the standards that have been created .... Why do we have so many standards for cell phones, why do we have different batteries for evry (damned) laptop, why do we have more serial protocols that I can name, ... standards are a great thing but they are never going to be respected by everybody.
    How many wires we need on the cable ... well ...
    Is everything digital? I think so. Than we need 2 wires, ground and signal.
    Even better why do we need wires?
    Infrared is a good solution or if you are thinking that the sun can get in the way and saturate your receiver why not radio.
    If the wireless pressure sensors work for dive computers, why not something like that for camera strobe communication?
    How fast should the communication be? I don't know but I don't think the ammount of data that has to be transmitted is that big so I don't see any problem there.
    So ... let's build one.
    Vlad
  17. I don't think a standard will hapen.
    Well that is the spirit. :lol:
    It is easy to name at least as many examples, where standards did work.
    The advantage of this system is that we are not dependent of the negotiations between manufacturers since there are so many adapters availible.
  18. I think that there is a good chance with the European housings manufacturers going to a standard: Subal, Seacam, Sealux, UK-Germany, Hugyphot etc (as they are all quite matey and all speak German).
    I think it is unlikely that they will be full international collaboration with N. American and Japanese brands.
  19. I'm sure we could learn a bit of german at Aquatica,especially if that helps the underwater photographer (including me) :(.
    The housing manufacturer's role is quite simple, all they have to do is provide a hole of the proper size for the "DIN" or whatever bulkhead, oh! and to make sure it's water tight :lol:.
    About time the industry got together for some simple day to day standarization, it's also time to bid the old Nikonos type connector good bye.
    Gutten tag, scheun unterwasser werk, Her Mustard. you see not that hard :blink:
