Canon EOS 5D, 12.8MP, full frame
Started by Jolly ·
  • 53Posts
  • 53Replies
  1. edit: 5D housings might be cheaper but on the other hand 5D body won't stay the same over future generations as the 1D bodies usually do ... but your 1Ds Ewa-Bag might be compatible to the 5D too  ;)
    The other thing to remember is time. I think that it will be unlikely that the will be a 5D housing out until this time next year. Whereas you can buy a 1D/1DS housing today. You can take a lot of pictures in one year!
    I also think that the housing manufacturers will not be queuing up to make housing for this camera. Ikelite, who is normally one of the fastest, tend to focus on mass market cameras. I can see Subal and Sea & Sea supporting this camera. Maybe Sealux too. Not convinced about Seacam, maybe?
    The 5D is expensive and likely to generate low numbers of sales for UW shooting. The clincher would be if it was full frame. If it is, then fisheye factor will make this a popular choice for UW photography and may persuade several companies to go with it.
    Judging from the interest expressed for my filters I would say that Nikon D70 + D100 out number Canon DSLRs about 3-4:1 in digital underwater photography.
    So an expensive, but sub-pro Canon, is unlikely to be a great investment for housing makers.
    I think that the 1DS Mk2 replacement will not have the same body. The main criticism of that camera by land photographers is the ergonomics of the body. SO I think that the current camera is the last that will fit in that housing (apart from the 1D Mk2N).
  2. Alex have a point
    Thats the reason that I have buy a Nikon D70 & a Nexus housing. I say to me , dont wait - take pictures - learn to use a DSLR underwater and dont invest much money.
    Then if sometning good will come out I will strike like ZEUS
    The 1DS Mk2 body is really old & big. Many Swedish fotografs criticasm this.
    If canon come out with a new Camera it will be a absolut new design...
    lambis
  3. I could not think of any reason for an 1Ds owner to switch to the 5D. You would loose the better body.
    But I think it's more an interesting camera to people who want full frame and higher resolution but not to spend 7000 bucks for the 1Ds MkII and its solid body.
    A used 1Ds is an attractive option too and the used prices won't really raise because of the 5D.
    Julian
    I'm not trying to compare it to the 1Ds Mk2 - quite a different price point, the 1Ds Mk 2 is undoubtably a better camera. But a used 1Ds ('Mk1', if you like) is about the same price. You get a pro body for your money, a weak AA filter (which is good for what most of us here use are cameras for, but not so great for fashion photogs) - and in return have to put up with outdated technology. The 1Ds doesn't even autorotate pictures taken in vertical. I'm sure Ansel Adams used to have to autorotate his JPEGs in the olden days, but it's pretty lame having to do so in 2005. But I digress...
    The 5D pretty much looks like my 10D, with a more prominent pentaprism. Ugh, consumer camera. People will think you're shooting with a D30 or something.
    As for the EWA-marine option - Jolly, I thought you were knowledable about such things. You should know that my U-AX won't fit a 1Ds, but would fit a 5D nicely. So if you buy one, give me a call and we'll do a deal.
    :D
    <edit> just came across this thread on LL about 20D and EWA-bag. http://www.luminous-landscape.com/cgi-bin/...=0;r=1;entry4
    Second comment down from 'benjammer' - LOL ;)
    Edited by whitey
  4. I agree that not every housing manufacture might jump into the gap between entry and pro bodies. For me, the 5D (if the specs are true) is a very nice underwater camera for two reasons: full frame for fisheye and a true uncropped big viewfinder like a film body or 1Ds (MkII). Both not available with a lower Canon DSLR model and both not less important for underwater. Add a street price of around 3000 and the resolution not available for this price anywhere else, it might be quiet attractive for some. Some even might prefer a smaller body than the 1D series. I am sure (if the camera is real - what I do believe today, but maybe not tomorrow) at least Subal and UK-Germany will build a housing. I would not be surprised if Sealux does not because they have their roots with Nikon like Seacam.
    If the camera is real, I will most probably order it and use it topside initially and will continue with my 10D underwater for some time.
    Just a thought: 5D with the simple Standard Sealux viewfinder (shrinking by 1.6) would roughly have the same image size as a 1.6 crop camera with the optional Sealux sportsfinder (almost 1:1). The viewfinder item may be interesting when investing in such a camera and saving additionally costs on viewfinder choice initially.
    Julian
    PS: Rob, I'll give you a call when I am up to a risky Ewa-Bag dive with my sweet 5D ;)
    Edited by Jolly
  5. Julian
    That with Standard or optional sportsfinder is very true.
    After I have buy my nikon I have think about it. The money that you invest for a sportsfinder you can invest for camera and housing.
    Lambis
  6. but this time Nikon seems to respond immediatley with a great D200:
    DX Format with 12.4 effective megapixels
    The new CMOS image sensor features high image quality and high-speed 4-channel data output
    New image processing algorithms combine with optimized analog and digital white balance to produce smoother, more consistent gradations with exceptionally pure color reproduction
    Continuous shooting: 3 frames per second (fps) at 12.4 megapixels for up to 10 consecutive NEF (Nikon Electronic Format) images; 5 fps for 18 NEF images at 6.8 megapixels
    3D-Color Matrix Metering II with ambient light sensor and 1,005-pixel RGB sensor further improves on Nikon’s acclaimed exposure metering system
    High-speed, high-precision 11-area AF system with 9 cross-type AF sensors deliver quick response and sharp focus, even under the most challenging shooting conditions
    Two new Adobe RGB color modes further expand professional color space options and also support for sYCC color space
    Excellent response with instant power-up and ultra-fast 52ms shutter release lag
    Top shutter speed of 1/8,000 second and flash sync speeds up to 1/250 second
    Faster read/write speed for the memory card and a USB 2.0 Hi-Speed interface for faster image transfer
    Large 2.5-inch LCD monitor for easy access to settings and information, as well as clear, flicker-free image preview
    Creative in-camera effects, Image Overlay and Multiple Exposure
    Functions such as World Time, automatic rotation of vertical compositions expand possibilities
    Lightweight, durable magnesium body
    Full support for Nikon's Creative Lighting System when used with the SB-800 or SB-600 Speedlights
    In addition to DX Nikkor lenses, the D200 supports more than 50 AF Nikkor lenses
    Nikon’s PictureProject software is included, enabling easy control over image adjustment and management
    Support for Nikon Capture 4 (version 4.3), a software application with the tools to assist the professional photographer
    NEF (RAW) format for the utmost in versatile, effective image control and correction
    JPEG and NEF (RAW) Combination Filing System enables simultaneous recording of NEF and JPEG data for the same shot
    source link:
    http://alpseb.free.fr/D200/NikonImagingNikonD200.htm
    I am not familiar with Nikon pre-release-leaks, but this sounds quite real to me.
    Julian
  7. "Two new Adobe RGB color modes further expand professional color space options and also support for sYCC color space"
    These aren't new. They are on the D2x. I think that this info has been copied and pasted from a D2x brochure and updated in certain areas by the hoaxer.
  8. Now I am starting to believe the 5D is real. Together with 5D rumors, there were also rumors of a new Canon lens, the 24-105 f/4L USM, well, it appears that the lens is real, check this official Canon site:
    Canon 24-105
    So, if the lens is real, I suspect the camera may be too.
  9. Luiz, you make my day! this lens was on the same Canon site screenshot (which was offline shortly afterwards of course) together with the 5D :)
    Julian
  10. Yes, that's why I think the 5D is real too! :)
  11. After reading the article and everyone's comments I must say this might be a step up for those in the underwater photography community who complained about the limitation of wide angle photography with the Canon - although image quality remains to be seen.
    On a side note: After reading day in and day out about the new advances in cameras it cracks me up to see just how 'digital' the photography industry has become. What I mean by this is how it evolves in very much the same way as computers do. It seems the hardware is always leaps and bounds ahead of the software end. Here we have all these fancy cameras yet we're still struggling with using multiple software applications in an attempt to produce decent results (ie. our varying results when attempting to reproduce sunburst with different applications) and keep some sort of sanity in the organization (ie. IPTC data implemention) of our now thousands of photographs shot in one day (slight exaggeration - I hope - for the fish's sake).
    I can certainly understand the ambivalence that film photographers might feel towards digital. Their old, simple ways have been replaced with countless hours in front of a PC (not to mention the hours spent reading books on Photoshop This And That) only to attempt to reproduce 'the moment' they know they captured.
    May the force be with us.
    PS - I predict after this whole digital craze is played out, Canon and Nikon will do like Ford has done with the T-Bird and Mustang -- we'll all be shooting with digital versions of Kwanon and Nikon I. :)
  12. Canon and Nikon will do like Ford has done with the T-Bird and Mustang -- we'll all be shooting with digital versions of Kwanon and Nikon I. :D
    Or the unthinkable, like the first Canon rangefinder that where made, will we see Nikon suplying lenses to Canon for its camera bodies :):D:D:D
