Ike port questions, Canon 20d, port #5503
Started by JamesWood ·
  1. I've got a Canon 20d with the 18-55mm EF-S lens in an Ike housing with port #5503.
    Although not required, I've been using a +4 diopter filter since I'm doing a lot of close focus wide angle work. I noticed, a bit to late, that the filter rubs against and scratches a rut into the port at both ends of the focal range (18 mm and 55 mm). For this and other reasons I wish to get a new port. Also, I can imagine that I will occasionally want to be able to use other filters with this lens such as the yellow NightSea barrier filter for florescent work.
    Questions:
    Has anyone else experienced this?
    Should I ditch the diopter and get the same port again?
    Should I get a different port? If so, which?
    Dr. James Wood
  2. The #5503 port is recommended for the lens "without" any add-ons as you found out. You can try the next size 1" longer dome #5503.50. Not sure if vignetting will occur at widest angle, but you may have to remove the shade.
  3. The #5503 port is recommended for the lens "without" any add-ons as you found out. You can try the next size 1" longer dome #5503.50. Not sure if vignetting will occur at widest angle, but you may have to remove the shade.
    Thank you Brett for the guidance.
