Replace front element of Nauticam dome ports
Featured Replies
6 hours ago, andieich said:
Has anybody attempted to change the front element of a Nauticam dome port? I found the replacement part (e.g. here: https://fotografit.eu/products/451-nauticam-service-accesories/5241-85-acrylic-dome-replacement-with-o-ring/) but no manual on how to actually do it
There is not much around on how to do this. I found a couple of posts discussing doing this for flat ports. the principle I believe is the same for dome ports. The hard part is getting to old o-ring out.
https://waterpixels.net/wp-archive/topic/68709-domeflat-port-deconstruction/#wp-post-447495
These may help a little. You could also ask the vendor is they can provide advice, or if they could do the replacement for you, I think I would be a bit nervous replacing the acrylic as it would be easier to scratch even with soft tools.
I took it off one time for polishing it… the 4.33 dome... It was a nightmare put it back with the old black oring.. I do the same with the 3.5 dome(n85) and finally was impossible with the original and I had to use an old grey port oring because was softer… 😅😅
Edited by FabioGal73
I cannot help with practical advise, but can tell the cost, for orientation, when made by a professional workshop (in this case Panocean in Germany):
I had to exchange the scratched glassdome of my Nauticam 140mm domeport. Material (port plus O-RIng) was 515 Euros and work was 75 Euros (add 20% VAT to both).
