Marelux Apollo C Strobe
Featured Replies
Marelux has released the Apollo C strobe, C is for combo (hybrid) combining a GN32 strobe with a 6000 lumen video with a CRI of 95 at 5000K. The beaded dome has a native 120 degree beam angle at 6000K and can be extended to 140 degrees with diffusers in 5500K and 4700K. Now taking orders at Marelux.co for a price of $849.00.
Product Specifications
1.Dimensions: Length x Diameter = 170 x 70mm
2.Weight in air 920g (with 2*21700 battery)
Weight in water 260g (with 2*21700 battery)
3.Depth Rating 100M
4.Uses 2 x 21700 lithium batteries (Battery should have continuous discharge current of 15A)
(Fits batteries with a length ranging from  70 mm to 76mm)
5.Support TTL, Olympus RC, HSS  (The TTL, HSS, and RC modes require compatible flash triggers to be used) Full Power Recycle Time: 0.8 second
6.Beam Angle: 120 °(140 ° with Diffuser )
7.Guide Number: 32 (on land)
8.Color Temperature: 6000k(5500k with white diffuser,4700k with yellow diffuser)
9.With a special designed MTL mode, support continuous flashes at 10 FPS within a maximum brightness of GN11
10.Fiber Trigger: with one fiber port that supports M, Pre Flash(Compatible with compact cameras),TTL, Olympus RC
(Supports RC-MANUAL, RC-TTL, RC-FP), M-HSS and MTL modes
11.Video Light : 6000 lumens on white(Runtime up to 40 minutes)
12.Full Power Flash Count: around 1000 times
13.Remote triggering capable
Built-in Optical Sensors for remote triggering
Uses Artemis 4500RMT 2.0-S
Completely eliminates the need for fiber optic cables
Edited by Phil Rudin
