Hi all,
I got some 12v standard bulbs, like the $.88 bulbs that Eagle Ray mentioned as backup as my european dealer had no spares in stock before i went to Indonesia.
I used my Dremmel tool to just sand the bulb surface 1 minute per bulb and good backup.
The spec for the ligthbulb provided is 32 hours burntime. When asking I got this reply from Fisheye.
"Hi when I read about your FIX Light HG20DX the specification states ・20W frosted glass super bright halogen (32 hour life)・
It that really true that the bulb will last only 32 Hours?
Yes, it is true.
This is special bright bulb by the lamp company Welch Alleyn.
Almost 50 % brighter than simillar same wattage same voltage lamps.
This cause to shorter life time.
We also have longer life bulb- 100h type, but it show over 30% darker than 30h type."
"The bulb is a littel bit customized from original Welch Alleyn.
We make the bulbs frosted as being sand-brasted, and a little bit some point to sellect lamps from thousands of lamps.
And 100 hour virsion is our original, so it is impossible to get those in your place."
