Lens adapter for WP-DC90
Started by auder ·
  • 22Posts
  • 22Replies
  1. Unfortunately I don't have pictures of the bayonet ring before attachment but here is a (rather bad) picture of it without the lens. It's screwed on so it can be removed and exchanged if I were to buy another kind of lens.
    It was quite tedious work to carve the thing but the lens does fit quite perfectly now.
    I still have some problems with the internal flash creating reflexions from the WA lens. I'm using the black rubber tube that was originally in the housing to shield, but I also need to put some tape inside the port.
    The acrylic is 5mm thick.
    Edited by dagobertb
  2. What glue did you use to this project?
    thanks
