Tokina 10-17 FE test fotos I
Started by Rai ·
  • 129Posts
  • 129Replies
  1. Well, went to the camera shop district today with the idea of hunting for an elusive 77mm diopter for my Canon 10-22mm...
    Didn't find a diopter, but ended up leaving the shop with a Tokina 10-17mm Fisheye instead! :D
    Rai - you said your friend was using his Tokina on a S&S D200 housing and Athena dome without any extension, right? This is how it looks on mine w/o any extension. Lens looks pretty far into the dome. Maybe a small extension might be better. 40mm ext I have is too long as there is vignetting from the dome itself (even with the shade removed).
    Edit: just noticed on the Athena site that the Nikkor 10.5 FE is recommended to be used w/o any extension and the Athena dome. The Tokina FE is just a 1/4" longer so maybe I don't need an extension :D . Will try to test it out if I can get some pool time soon.
    and just a quick street shot on the way back from the store... Interesting lens...
    Edited by pakman
  2. Sorry for the answer delay. I was on holidays.
    Yesterday I talked with my friend and told me the he uses the Athena dome with no extension ring without any trouble. He also told me that he was pretty sure (but no testing indeed) that with a extension ring, the vignetting will probably appear.
  3. Sorry for the answer delay. I was on holidays.
    thanks for replying Rai. actually I noticed that there is vignetting even above water with the ext. (with and without the dome hood)
  4. From my first dives with the 10-17 lense.
    It looks promising.
    Used it on an Aquatica D2X with a 6" port.
    I modified an existing ( Canon 50mm macro ) gear to use the zoom
    Edited by pmooney
  5. Check out those corners in Peter's pics........
    Fisheye's rule!!!!
    It will be a hit, especially for us Canon shooters. Plus it is SO compact it even fits in the little Ikelite #5503 "standard" 6" dome port :P
    Of course, the 8" dome port wil be used for over / under images.....
    dhaas
    Edited by dhaas
  6. oh that is beautiful Peter... Can't wait to give this lens a try in Palau next month!
  7. Rai - you said your friend was using his Tokina on a S&S D200 housing and Athena dome without any extension, right? This is how it looks on mine w/o any extension. Lens looks pretty far into the dome. Maybe a small extension might be better. 40mm ext I have is too long as there is vignetting from the dome itself (even with the shade removed).
    Edit: just noticed on the Athena site that the Nikkor 10.5 FE is recommended to be used w/o any extension and the Athena dome. The Tokina FE is just a 1/4" longer so maybe I don't need an extension :P . Will try to test it out if I can get some pool time soon.
    Hi Pakman,
    It's pretty obvious from your rig shot that you ideally want an extension tube in there. With that Athena dome I'd say you really want the longest extension that doesn't cause vignetting. you can work that out in air. Just unhook the dome and move it away from the housing until you start to see some of it in the captured images (viewfinder lies obviously). Then move it back about 1cm for comfort.
    By the looks of the image, I'd guess the 40mm ring is going to be too much and you'll be wanting the 22mm.
    Martyn
  8. you're probably right Martyn. There is just the slightest of vignetting with the 40mm ext (only ext I have). I did do some quick bath tub tests (have't had time to test in a pool) and tried some close focus shots. Looked pretty nice. But will give the 22mm ext a shot.
  9. Has anyone tried this lens on a 5D or 1ds? It'd be interesting to see how much of the image beyond the cropped sensor edge is useful.
    Edited by herbko
  10. OK, i NEED this lens.
    I am going to Japan this week to pick up my new Eos 30D with INON X2 housing ... i know it is quite hopeless ... but does anyone know, if it's possible to fit this lens under the Dome-port for the X2.
    Extensions, yes or no? >> japanese shops offer a Dome for the canon 15mm Fisheye ... maybe this one is enough? and thay also offer one with extension for the canon 14 mm lens.
    anyone knows if one of the two might fit? or something else?
    thanks
  11. By the looks of the image, I'd guess the 40mm ring is going to be too much and you'll be wanting the 22mm.
    Martyn
    well picked up a 22mm extension this weekend. no vignetting during topside tests. Will need to get into a pool sometime.
  12. I got my lense from Yodobashi Camera @ Uemeda Station Osaka on New Years Eve.
    They are the Japanese equivelent of B&H Photo and have stores in Tokyo & Osaka, and do have some english speaking staff for gaijin travellers.
    Got this self portrait yesterday.
    and cropped
    Edited by pmooney
  13. well picked up a 22mm extension this weekend. no vignetting during topside tests. Will need to get into a pool sometime.
    If vignetting didn't appear in topside tests, it won't appear UW. But you still have to test in the pool for corner blurring. Better if you try with and without the extension. If blur doesn't shows up in both cases you can choose using the extension or not, depending on what you wanna do: over/under with extension and CFWA without it in order of taking profit of the really small minimum focus distance.
    Rai
  14. LOL! Nice pics Peter! :D which camera was that shot with?
    Rai - thanks for the advice... will give both setups a try
  15. I have been shooting this lens on a D2X in an Aquatica housing , no extension ring and have been using 6'' custom dome that I had made.
    It really has been a lot of fun, although I have spent most of my time at 10mm rather than the 17mm end which had been my norm. I am starting to get a feel for it now and am really looking forward to using it on a big dome as soon as the weather breaks. :D:D
    Edited by pmooney
  16. oops silly me, I forgot you had mentioned that already when you posted the turtle pics...
  17. I am very interested in this lens; especially for my upcoming snorkel trip to the Silver Banks in March :-) But does anyone know how it might perform behind a 6" dome? I am actually using the Canon 17-40 lens behind the Ikelite #5503.51 6" dome at the moment. Ike's port chart says to use the #5503 6" dome or the 8" dome fir this Tokina fisheye. What will happen if I use the 5503.51 port instead?
    Thanks in advance.
  18. I went to a local freshwater site at the weekend to try out the Tokina lens with my D70 and Ike housing. First problem I had was that when I put the camera in the housing I could quite clearly see the shade at 10mm. I removed the shade but would prefer the minor protection this gives. On quite a lot of shots I had some flare from the flash on the left side and a strange curved line which is caused by the flash reflecting off something or refracting through the edge of the port. If it's the latter then trimming the shade and replacing it should help.
    At 17mm and F8 the corners seem reasonable sharp.
    This shot shows the flare problem. It also shows the fisheye distortion. Again shot at f8.
    There's a bit of a hotspot on this one but less, I think because there's a subject on the left.
    Finally a couple of available light shots. In each case I had to dial in about -1.5 exposure compensation to stop the top of the picture burning out. It was a dark day with low vis and I guess the extreme wide angle was picking up too much variation between the dark bottom and the surface light for the meter to cope.
    1/45 at f3.5 no major soft corners even wide open.
    1/15 at f3.5
  19. Ken, thanks for posting the pics. I'm not sure if I see that flare line you're referring to... are you talking about the backscatter on the left (pic #3)? I'm not an expert but I did notice when I took this lens down this weekend for a quick 10min test dive that I had to be a lot more careful with strobe placement (vs my old 10-22 lens) otherwise I'd get similiar backscatter/ hotspots...
    Edited by pakman
