In an effort to come to some type of iTTL solution for the Nikon D2x , I purchased two Fantasea SB-800 flash housings to go with my Aquatica housing. That was last October.
The flashes will not work correctly when hard-wired together as other posters to this site have said.
Various posters to this website had surmised that the infrared signal was too weak to pass directly through water and cause the slave unit to work as required for iTTL flash exposure on a consistent basis. At this point, some of the other posters had designed and implemented their own fibre optic solutions. A search of the Wetpixel website will show what other photographers have done.
With that information in mind, I cobbled together a quick-and-dirty fibre optic link between the two flashes by cutting the ends off a fibre optic audio cable and used a friction fit to mount the ends in two small pieces of Plexiglas.
Using a paper punch to cut two holes in two pieces of Velcro I mounted the fibre optic cable ends to the SB-800 housings adjacent to the flash tube and infrared sensor. The holes were cut in the Velcro to make sure the signal from the fibre optic cable reached the flash sensor unimpeded. Total cost including the Plexiglas scraps (given for free from a local glass dealer), and not the flash housings of course, cost roughly $17.95 CAN with the elbow grease thrown in for free by yours truly.
But, does it work?
Yes it does, however, in a (very) rough comparison to the quality and quantity of light discharged by my two Ikelite DS-200s, I find it is not the preferred option. That’s the best way I can put it. The two SB-800s in iTTL mode do not have the beam coverage or the power to light up the scene as the DS-200s do. The DS-200s also have the luxury of aiming lights built into the strobe to make strobe positioning more user friendly than the SB-800s.
Shooting macros may be the one area where the SB-800s could outshine the DS-200s (sorry for the pun!). As I am not one to shoot a lot of macros, I will leave it to others more taken with macros to shine a little more light on the subject (O.K., O.K. no more puns!).
Bottom Line: I tried them on a dive trip in November and they work in the configuration listed in the above paragraphs, but didn’t even think to bring them on two subsequent dive trips in January and February, preferring the quality and quantity of the light from my DS-200s instead. For me, the SB-800s will be another photographic tool with which to rely on, but only in a limited fashion.
I am now getting my hopes up for an-already-announce-but-never-produced-as-yet Ikelite iTTL cord for non-Ikelite housing hopefully to be produced sometime before the second coming of you know who……..
Hope that helps.
